FS: SOLZD>>>>Side shifter transaxle full gear assembly.....(no case) |
dlee1967 |
Apr 19 2012, 08:55 AM
V8Lurker Group: Members Posts: 540 Joined: 20-February 03 From: Splendora, TX Member No.: 327 Region Association: None |
SOLD...thank you.
I pulled down a 914 901 box to remove a lsd for another project and am offering for sale the complete gear stack assemblies and sliders. This is a great way to refresh your damaged gearbox and does not even require that you remove the gearbox, or axles. Please see Dr. Evils threads for instructions. It also is cheaper than trying to successfully ship an entire gearbox. This setup has minimal wear, most evident on the reverse gear as expected. Please see the following pictures showing close ups of the gears and dogs. Came out of a car that shifted well. Larger pictures are available if you want to blow them up and see the detail. Please send email address with your request for the pictures. Thank you.... $250 shipped in the CONUS. David Lee, Houston, TX |
Lo-Fi Version | Time is now: 17th May 2024 - 09:05 PM |
