914-6 Steering Column Bearings |
pete000 |
Apr 22 2012, 11:09 PM
Senior Member Group: Members Posts: 1,885 Joined: 23-August 10 From: Bradenton Florida Member No.: 12,094 Region Association: South East States |
I have notice my steering column bearings seem to be pretty worn. There seems to be a lot of up and down play in the steering column.
Just found this, looks like I need a new busing or the spring might be missing. Have to pull it apart and check. http://forums.pelicanparts.com/porsche-911...g-quickfix.html |
chuckc |
Apr 23 2012, 12:25 PM
Member Group: Members Posts: 196 Joined: 30-August 10 From: Astoria NY Member No.: 12,123 Region Association: North East States |
I have notice my steering column bearings seem to be pretty worn. There seems to be a lot of up and down play in the steering column. Just found this, looks like I need a new busing or the spring might be missing. Have to pull it apart and check. http://forums.pelicanparts.com/porsche-911...g-quickfix.html I have a 75 /4 that had a lot of play in the collumn. I just fixed mine this past friday with a new bearing and installed a momo adapter and new wheel. I took detailed pics so I could post the steps since I couldn't find a step by step and my haynes was next to worthless. I'm not sure if the fix will be exactley the same for you since you have a 6. The pelican post looked like it was for 911s, my car had no spring, or that c sleeve shown in the Pelican 911 link. here is the link I posted for replacing the bearing on a 914-4. http://www.914world.com/bbs2/index.php?showtopic=182321 peace, chuck |
Lo-Fi Version | Time is now: 9th May 2024 - 04:56 AM |
