Cool 914 wheel - proly $$ thou, check out the site |
Mike D. |
May 9 2003, 03:55 PM
OK, It runs now, and pretty good too! Group: Members Posts: 1,445 Joined: 3-January 03 From: Santa Clarita, Ca Member No.: 85 Region Association: None |
Brad Roberts |
May 9 2003, 04:44 PM
Very nice.
B |
Mark Henry |
May 9 2003, 06:14 PM
Mueller talked about cutting down a 4 bolt Fuch and then turning it into a 16 or 17 inch X 6 or 7 inches, I think he may have lost interest since he got his rice wheels. (IMG:style_emoticons/default/wink.gif)
I wonder if these guys would do it and how much. http://usacomp.com/Modular.htm Also good off-set info: http://usacomp.com/Offset.htm |
Mueller |
May 9 2003, 06:24 PM
The outer rim halves I was looking into using don't have the saftey bead on them so I passed on the project. Also the 4-bolt Fuch does not have as much extra material on the OD of the center section like the 16x6 Fuch has.
For about 250 per wheel, I know a manufacture in New Zealand that will make 3 piece wheels per my (your) design. So making a 4-bolt Fuch looking rim in larger diameters and widths is not that big of a deal. I know there is a charge for the pattern (cast), but I don't think it is too much...his prices on new spun outer halves is very reasonable. |
Lo-Fi Version | Time is now: 20th May 2024 - 02:22 AM |
