Type 1 oil pump cover |
Harpo |
May 24 2012, 11:08 AM
Senior Member Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
I purchased a type 1 oil pump (modified for use in a type 4) will I need a type 1 cover for it as well.
Thanks DAvid |
Valy |
May 24 2012, 11:14 AM
Senior Member Group: Members Posts: 1,676 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
I purchased a type 1 oil pump (modified for use in a type 4) will I need a type 1 cover for it as well. Thanks DAvid Yes, you do. See this: http://www.914world.com/bbs2/index.php?s=&...t&p=1675905 |
76-914 |
May 24 2012, 02:04 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,503 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
IIRC, you need to shave/grind 1mm off the end of the drive tang
mrbubblehead |
May 24 2012, 04:53 PM
Twodollardoug Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
Lo-Fi Version | Time is now: 19th May 2024 - 10:22 AM |
