part number needed, for turn signal switch |
freezing14 |
Oct 14 2004, 08:36 AM
freezing14 Group: Members Posts: 435 Joined: 21-June 04 From: brockville , Ontario, Canada Member No.: 2,233 |
As I am putting the car together, I test everything to make sure I will not have to disassemble it later along with the stuff that goes on top,, I am still working electrical glitches,, and now i need to find a turn signal switch as mine is cracked inside, the P # is 914 613 91314 but since it is a 1972 1.7 the housing should be the same as the VW and 1 very interesting thing,, if you call the dealer for lets says 0-ring and you as the same 0-ring with VW and P # for the same part the VW is usually quite a bit cheaper anyone have the VW number for the turn signal switch so that i can try to find it unless you know of anyone who sells them or if you have 1 for sale
Mark Henry |
Oct 14 2004, 09:29 AM
Mike (mikes914's) most likly has one, if you don't know the number PM me for it, I don't have it handy right now.
I'll check my stash too. Some years will take a 411 switch (I think) but I don't know what years. |
Lo-Fi Version | Time is now: 17th May 2024 - 02:35 PM |
