Best Exhaust???, 2.0, or 1.7 stock, or Bursch. |
dmenche914 |
Oct 16 2004, 10:29 AM
Senior Member Group: Members Posts: 1,212 Joined: 27-February 03 From: California Member No.: 366 |
I have a 2.0 liter motor, believe to be stock configuration, 73 or 74 model year D-Jet)
I have two options of exhaust systems available to me. What would be best of these two options? Also reason(s) why one option is better or not. What do you all know? option 1..... Stainless steel 1.7/1.8 heat exchangers (the ones that kick upwards prior to the muffler) along with an aftermarket bursch pipes and muffler. option 2..... Stainless steel 2.0 heat exchangers (the ones that go straingt into the muffler) and a stock 73/74 2.0 liter Muffler. The Bursche pipes and muffler weight is 15 lbs, the big rounded stock 2.0 muffler wieght is 24 lbs. There is no significant weight difference betweent he heat exchangers. The Bursch pipes are a 4 into 2 into 1 system. (as opposed to 4 into 1 system). So what is the best choice in this application? Trade offs? and why? thanks for your inputs! dave |
Oct 16 2004, 11:14 AM
Resident German Group: Admin Posts: 41,641 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
option 1 ...
the difference between the 1.8 and 2.0 SS HEs is minimal, if they're SSIs and the bursch flows much better than the original muffler, so, i vote for option 1! (IMG:style_emoticons/default/wink.gif) Andy |
Mueller |
Oct 16 2004, 11:27 AM
QUOTE the difference between the 1.8 and 2.0 SS HEs is minimal, if they're SSIs and the bursch flows much better than the original muffler, so, i vote for option 1! much better??? didn't Grassroots do a dyno comparison? I thought they said the stock muffler was better than the Bursch???? |
dmenche914 |
Oct 16 2004, 11:56 AM
Oh, Oh Two respected knowledgable 914'ers and two different opinions. Now I'm more confused!!!!
Maybe each is much better at different rpms??? Yes, I would think the small difference in SS heat exch. bend would make zilch flow difference between the heat exch. types. So it should come down to flow difference between the post heat exch. pipes/muffler. At least the Busch is 9 lbs less hanging out back than the stock 2.0 muffler. Anyone got a link to flow data, or have done a conversion so you have seat of the pants data? Thanks. dave |
rhodyguy |
Oct 16 2004, 01:02 PM
the 2.0 willl give you at least 1 other option with regards to exhaust systems.
kevin |
anthony |
Oct 16 2004, 01:16 PM
2270 club Group: Benefactors Posts: 3,107 Joined: 1-February 03 From: SF Bay Area, CA Member No.: 218 |
QUOTE I thought they said the stock muffler was better than the Bursch???? I've heard in the past that the Bursch just moves the torque/hp curve a little forward towards higher rpms. The difference is minor. |
Oct 16 2004, 01:22 PM
QUOTE(anthony @ Oct 16 2004, 12:16 PM) I've heard in the past that the Bursch just moves the torque/hp curve a little forward towards higher rpms. The difference is minor. that is partially correct ... a more free flowing exhaust will move the torque/hp curve towards higher rpms. but it will also increase the peak torque/hp at the same time. you will lose some low-rpm torque/hp and gain more torque/hp at slightly higher rpms ... plus, the bursch sounds better than the stock exhaust! (IMG:style_emoticons/default/biggrin.gif) Andy |
Bleyseng |
Oct 16 2004, 01:25 PM
Wrong! the tests showed a 1hp gain at mid rpms with a loss at higher rpms over the stock 2.0l banana muffler.
Best is the 2.0l SSI exchangers and a stock muffler OEM. For sound use the Bursch as it sounds cool and costs less. Geoff |
Elliot_Cannon |
Oct 16 2004, 01:29 PM
Senior Member Group: Retired Members Posts: 1,922 Joined: 26-March 03 From: Orange County Ca Member No.: 480 Region Association: None |
I think you should go with the one that sounds the best.
Cheers, Elliot |
Rog914 |
Oct 16 2004, 01:39 PM
914 Fanatic Group: Members Posts: 129 Joined: 5-January 03 From: Reisterstown,Md Member No.: 93 |
I've the "Triad" muffler on my 2.0 & like it better than any of the other.
Ralph 74 2.0 |
rhodyguy |
Oct 16 2004, 02:03 PM
that's the "at least 1 other option". off to dave's to put on some carbs.
kevin |
Oct 16 2004, 02:17 PM
QUOTE(Bleyseng @ Oct 16 2004, 12:25 PM) Wrong! the tests showed a 1hp gain at mid rpms with a loss at higher rpms over the stock 2.0l banana muffler. where is the data ? i thought they tested a /6 setup? (IMG:style_emoticons/default/idea.gif) Andy |
Bleyseng |
Oct 16 2004, 03:20 PM
I don't have that Grassroots mag handy as its stored do to the last effin move.
They dyno tested: Stock OEM muffler Bursch(same as stock) CFR header (best) That four tip muffler (lost hp) |
RustyWa |
Oct 16 2004, 04:23 PM
Working Member Group: Members Posts: 610 Joined: 2-January 03 From: Kent, WA Member No.: 72 |
QUOTE(Bleyseng @ Oct 16 2004, 01:20 PM) I don't have that Grassroots mag handy as its stored do to the last effin move. They dyno tested: Stock OEM muffler Bursch(same as stock) CFR header (best) That four tip muffler (lost hp) To the rescue! Attached image(s) |
Joe.D |
Oct 16 2004, 06:15 PM
MCMLXXIII MCCM Group: Members Posts: 132 Joined: 16-June 03 From: Southern Maine Member No.: 830 |
Just my humble opinion....FWIW.
I have a new Bursch on a 1.8 L-jet and I think its too damned noisy. Even my hard of hearing old neigbor has commented that he has looked outside for the delivery truck when I go by (ouch!) . I just don't enjoy the constant low "drone" at highway speeds with the roof off. But then, I'm not racing, or even AX. Just daily driver. With what I know now, I wish I'd gone for a stock one, but the money's been spent. Live and learn... Joe. |
jd74914 |
Oct 16 2004, 07:09 PM
I have to say I've heard the CFR muffler (by CFR you mean the tangerine racing stuff), and know Chris Folley and it sounds awesome. The craftmanship also is great (IMG:style_emoticons/default/smilie_pokal.gif) . I wish I had enough ($$$) to buy one (IMG:style_emoticons/default/wub.gif).
On the question though, my Bursch sounds really good (IMG:style_emoticons/default/wink.gif) |
dflesburg |
Oct 16 2004, 07:14 PM
Senior Member Group: Members Posts: 1,720 Joined: 6-April 04 From: Warm and Cheerful Centerville Ohio Member No.: 1,896 Region Association: None |
My favorite exhaust was always the Thunderbird exhaust system with the tuned mid pipe.
Wish I could find an old one so I could have it copied. |
MarkV |
Oct 16 2004, 09:52 PM
I replaced my Bursch with a stock 2 liter banana.
The Bursh was annoying loud. I set off car alarms in the mall parking lot. The stock banana muffler seems to make better low to mid range torque. |
dmenche914 |
Oct 16 2004, 10:30 PM
i had the Bursch system on my 1.7 engine, liked the sound, and the fact i could set off car alarms with it!
Looks like the difference is minimal with the Bursch, the sound was ok by me, I am leaning towards the Bursch, also, as it is 9 lbs lighter also. |
Joe Ricard |
Oct 17 2004, 06:08 AM
Well depending on which SSI model you have. You need the matching Muffler. 1.7 1.8 use the same muffler stock and Bursch. 2.0L with the straight SSI requires 2.0L Muffler stock for tooling around town probably better. Anything over 4000 RPM and Bursch, Herry Hunter Header, or CFR Header are where the power and of course noise is.
Lo-Fi Version | Time is now: 17th May 2024 - 09:32 PM |
