Sasquatch Part III Audi 1.8t transplant..., PCV upgrades finally... |
Mike Bellis |
Jun 10 2012, 05:41 PM
I have A.D.D. I admit it. I also can't leave well enough alone. I got really motivated by Andrew Dalen and seeing a 914 with Subie power driving to WCR12 from Idaho. What a beautiful car...
I stumbled on a steal of a deal for a 2001 Passat 1.8t, Audi ATW engine and 5 speed transaxle. Long story short and here you go. New engine cleaned and ready for fab time. The exhaust and turbo have been removed before power washing. Here is a link to Part I http://www.914world.com/bbs2/index.php?act...=0#entry1396734 Part II http://www.914world.com/bbs2/index.php?showtopic=172455 Here is the challenge. The transaxle. Either I fab an adapter, Fab an axle to take 1 Porsche CV and 1 Audi/VW CV or Replace with Boxster tranny, that will: Bolt right on, Shifter is cheap and available and requires less fab time. I'm leaning to the Boxster due to the 100mm Porsche CV flange. The Audi is 114mm. This is whats left of the wiring after the car gets gutted. The ECU and gauge cluster have a symbiotic relationship. They work together and have to stay together to run. It looks like it will fit nicely into the stock location. I may have to adjust the column lower and build an trim ring around the cluster. |
Mike Bellis |
Jun 10 2012, 06:51 PM
Here is the stock K03 turbo. It hangs from a chincy looking cast iron manifold. There are high flow cast replacement manifolds cheap. A K04 is a bolt on upgrade for this turbo. Bigger I guess... More better power (IMG:style_emoticons/default/biggrin.gif)
The stock dump/CAT pipe is 4" OD. Looks like connecting to my 4" exhaust is easy. I picked up this 4" flex too. A V band on one side and done. I will gut the CAT and shorten the chamber after I get to engine in the car. Ever wondered what was inside? Is this platinum? Should I recycle it? |
Lo-Fi Version | Time is now: 25th April 2024 - 04:06 PM |
