Sasquatch Part III Audi 1.8t transplant..., PCV upgrades finally... |
Mike Bellis |
Jun 10 2012, 05:41 PM
I have A.D.D. I admit it. I also can't leave well enough alone. I got really motivated by Andrew Dalen and seeing a 914 with Subie power driving to WCR12 from Idaho. What a beautiful car...
I stumbled on a steal of a deal for a 2001 Passat 1.8t, Audi ATW engine and 5 speed transaxle. Long story short and here you go. New engine cleaned and ready for fab time. The exhaust and turbo have been removed before power washing. Here is a link to Part I http://www.914world.com/bbs2/index.php?act...=0#entry1396734 Part II http://www.914world.com/bbs2/index.php?showtopic=172455 Here is the challenge. The transaxle. Either I fab an adapter, Fab an axle to take 1 Porsche CV and 1 Audi/VW CV or Replace with Boxster tranny, that will: Bolt right on, Shifter is cheap and available and requires less fab time. I'm leaning to the Boxster due to the 100mm Porsche CV flange. The Audi is 114mm. This is whats left of the wiring after the car gets gutted. The ECU and gauge cluster have a symbiotic relationship. They work together and have to stay together to run. It looks like it will fit nicely into the stock location. I may have to adjust the column lower and build an trim ring around the cluster. |
Andyrew |
Sep 19 2012, 10:56 PM
Mike, are you going to run the stock turbo/tune for the initial testing and then upgrade?
GT28r is a great turbo.. I wish I took you for a ride in the Audi prior to me blowing that turbo... Turbo should fit fine, the 914 has more side to side room than most cars, I would go with a bottom mount turbo due to the exhaust and the firewall clearance (VS going with like the SPA manifold..). Not very many available though... I see one on ebay, but not sure how long it would last before it cracked... ( My APR one is bottom, but its made of Iconell, so it will never crack...). |
Mike Bellis |
Sep 20 2012, 08:05 AM
Mike, are you going to run the stock turbo/tune for the initial testing and then upgrade? GT28r is a great turbo.. I wish I took you for a ride in the Audi prior to me blowing that turbo... Turbo should fit fine, the 914 has more side to side room than most cars, I would go with a bottom mount turbo due to the exhaust and the firewall clearance (VS going with like the SPA manifold..). Not very many available though... I see one on ebay, but not sure how long it would last before it cracked... ( My APR one is bottom, but its made of Iconell, so it will never crack...). I'm going to have 034 flash the ECU and build to the tune. I'm also running a new crankcase evacuation system to intercept the PCV system and draw constant vacuum on the crankcase. Since I'm using the Meth, the tune may be aggressive for pump gas. |
Lo-Fi Version | Time is now: 24th April 2024 - 08:55 AM |
