Sasquatch Part III Audi 1.8t transplant..., PCV upgrades finally... |
Mike Bellis |
Jun 10 2012, 05:41 PM
I have A.D.D. I admit it. I also can't leave well enough alone. I got really motivated by Andrew Dalen and seeing a 914 with Subie power driving to WCR12 from Idaho. What a beautiful car...
I stumbled on a steal of a deal for a 2001 Passat 1.8t, Audi ATW engine and 5 speed transaxle. Long story short and here you go. New engine cleaned and ready for fab time. The exhaust and turbo have been removed before power washing. Here is a link to Part I http://www.914world.com/bbs2/index.php?act...=0#entry1396734 Part II http://www.914world.com/bbs2/index.php?showtopic=172455 Here is the challenge. The transaxle. Either I fab an adapter, Fab an axle to take 1 Porsche CV and 1 Audi/VW CV or Replace with Boxster tranny, that will: Bolt right on, Shifter is cheap and available and requires less fab time. I'm leaning to the Boxster due to the 100mm Porsche CV flange. The Audi is 114mm. This is whats left of the wiring after the car gets gutted. The ECU and gauge cluster have a symbiotic relationship. They work together and have to stay together to run. It looks like it will fit nicely into the stock location. I may have to adjust the column lower and build an trim ring around the cluster. |
Andyrew |
Sep 20 2012, 08:44 AM
The PCV system tends to crack and disintegrate, especially by the block. O34 has solutions to that.. Make sure you replace all the plastic bits there..
Mike Bellis |
Sep 20 2012, 09:47 AM
The PCV system tends to crack and disintegrate, especially by the block. O34 has solutions to that.. Make sure you replace all the plastic bits there.. I have the 034 PCV aluminum bung to remove all the plastic bits. I need to decide if I want to build a catch can or buy one to go inlive with the evac. |
Lo-Fi Version | Time is now: 28th March 2024 - 07:50 AM |
