Sasquatch Part III Audi 1.8t transplant..., PCV upgrades finally... |
Mike Bellis |
Jun 10 2012, 05:41 PM
I have A.D.D. I admit it. I also can't leave well enough alone. I got really motivated by Andrew Dalen and seeing a 914 with Subie power driving to WCR12 from Idaho. What a beautiful car...
I stumbled on a steal of a deal for a 2001 Passat 1.8t, Audi ATW engine and 5 speed transaxle. Long story short and here you go. New engine cleaned and ready for fab time. The exhaust and turbo have been removed before power washing. Here is a link to Part I http://www.914world.com/bbs2/index.php?act...=0#entry1396734 Part II http://www.914world.com/bbs2/index.php?showtopic=172455 Here is the challenge. The transaxle. Either I fab an adapter, Fab an axle to take 1 Porsche CV and 1 Audi/VW CV or Replace with Boxster tranny, that will: Bolt right on, Shifter is cheap and available and requires less fab time. I'm leaning to the Boxster due to the 100mm Porsche CV flange. The Audi is 114mm. This is whats left of the wiring after the car gets gutted. The ECU and gauge cluster have a symbiotic relationship. They work together and have to stay together to run. It looks like it will fit nicely into the stock location. I may have to adjust the column lower and build an trim ring around the cluster. |
Andyrew |
Sep 22 2012, 09:49 PM
350 with that turbo will take ~ 22psi. I had 330hp (255awhp) at 19psi and I ran ~ 96 octane, so with meth that should be about right. That turbo will take 25psi.. If it was ME, I would run 15psi on the street without meth, then have a scramble boost option on the boost controller hooked up to the meth and run like 22-23psi.. 275hp on the street with another 100hp at the push of a button/switch... Mmmmm Tasty (IMG:style_emoticons/default/smile.gif)
That would keep the turbo and rods nice and healthy (IMG:style_emoticons/default/smile.gif) |
Mike Bellis |
Sep 23 2012, 05:26 PM
350 with that turbo will take ~ 22psi. I had 330hp (255awhp) at 19psi and I ran ~ 96 octane, so with meth that should be about right. That turbo will take 25psi.. If it was ME, I would run 15psi on the street without meth, then have a scramble boost option on the boost controller hooked up to the meth and run like 22-23psi.. 275hp on the street with another 100hp at the push of a button/switch... Mmmmm Tasty (IMG:style_emoticons/default/smile.gif) That would keep the turbo and rods nice and healthy (IMG:style_emoticons/default/smile.gif) I need a new boost controller. My HKS crapped out on me. I've been running old school with a manual boost controller. My Meth controller is progressive. at 10psi (or where ever I set it) it will start a low flow ramping up to the max setting. So either I get a new electronic boost controller or modulate the throttle/manual boost control to keep the pressure at bay. I will have 034 tune it to the max hp that is still reliable. No more speed boat action like the rotary. Although, fishtailing the car up the on ramp with McMark was fun! We'll see if this engine can do the same... (IMG:style_emoticons/default/evilgrin.gif) |
Lo-Fi Version | Time is now: 29th March 2024 - 12:15 AM |
