Sasquatch Part III Audi 1.8t transplant..., PCV upgrades finally... |
Mike Bellis |
Jun 10 2012, 05:41 PM
I have A.D.D. I admit it. I also can't leave well enough alone. I got really motivated by Andrew Dalen and seeing a 914 with Subie power driving to WCR12 from Idaho. What a beautiful car...
I stumbled on a steal of a deal for a 2001 Passat 1.8t, Audi ATW engine and 5 speed transaxle. Long story short and here you go. New engine cleaned and ready for fab time. The exhaust and turbo have been removed before power washing. Here is a link to Part I http://www.914world.com/bbs2/index.php?act...=0#entry1396734 Part II http://www.914world.com/bbs2/index.php?showtopic=172455 Here is the challenge. The transaxle. Either I fab an adapter, Fab an axle to take 1 Porsche CV and 1 Audi/VW CV or Replace with Boxster tranny, that will: Bolt right on, Shifter is cheap and available and requires less fab time. I'm leaning to the Boxster due to the 100mm Porsche CV flange. The Audi is 114mm. This is whats left of the wiring after the car gets gutted. The ECU and gauge cluster have a symbiotic relationship. They work together and have to stay together to run. It looks like it will fit nicely into the stock location. I may have to adjust the column lower and build an trim ring around the cluster. |
Chris H. |
Sep 23 2012, 04:49 PM
Senior Member Group: Members Posts: 4,027 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
Hey Mike,
So the clearance looks pretty good? Not much hacking expected in the engine bay/trunk? Really cool build BTW. |
Mike Bellis |
Sep 23 2012, 05:21 PM
Hey Mike, So the clearance looks pretty good? Not much hacking expected in the engine bay/trunk? Really cool build BTW. I may need to encroach into the rear trunk a little. Won't really know until I stuff it in there. If I do, it's important to keep room for the targa top. I think it will work out just fine. I can hardly wait to drive this one. It will be as well mannered as a stock Audi engine until I put my foot into it. (IMG:style_emoticons/default/driving.gif) Thanks for the kind words. It helps keep me motivated... (IMG:style_emoticons/default/smile.gif) |
rohar |
Sep 23 2012, 05:36 PM
Senior Member Group: Members Posts: 924 Joined: 25-October 08 From: spokane Member No.: 9,685 Region Association: None |
Hey Mike, So the clearance looks pretty good? Not much hacking expected in the engine bay/trunk? Really cool build BTW. I may need to encroach into the rear trunk a little. Won't really know until I stuff it in there. If I do, it's important to keep room for the targa top. I think it will work out just fine. I can hardly wait to drive this one. It will be as well mannered as a stock Audi engine until I put my foot into it. (IMG:style_emoticons/default/driving.gif) Thanks for the kind words. It helps keep me motivated... (IMG:style_emoticons/default/smile.gif) After putting a 16v on a 901 in this chassis, I'm pretty sure you shouldn't have to chop up the trunk. There's a few water fittings that are gonna want to go where the body currently is. It's easy enough to fab up new flanges and re-route. Much better solution than cutting up chassis steel. |
Lo-Fi Version | Time is now: 18th April 2024 - 10:31 PM |
