Sasquatch Part III Audi 1.8t transplant..., PCV upgrades finally... |
Mike Bellis |
Jun 10 2012, 05:41 PM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
I have A.D.D. I admit it. I also can't leave well enough alone. I got really motivated by Andrew Dalen and seeing a 914 with Subie power driving to WCR12 from Idaho. What a beautiful car...
I stumbled on a steal of a deal for a 2001 Passat 1.8t, Audi ATW engine and 5 speed transaxle. Long story short and here you go. New engine cleaned and ready for fab time. The exhaust and turbo have been removed before power washing. Here is a link to Part I http://www.914world.com/bbs2/index.php?act...=0#entry1396734 Part II http://www.914world.com/bbs2/index.php?showtopic=172455 Here is the challenge. The transaxle. Either I fab an adapter, Fab an axle to take 1 Porsche CV and 1 Audi/VW CV or Replace with Boxster tranny, that will: Bolt right on, Shifter is cheap and available and requires less fab time. I'm leaning to the Boxster due to the 100mm Porsche CV flange. The Audi is 114mm. This is whats left of the wiring after the car gets gutted. The ECU and gauge cluster have a symbiotic relationship. They work together and have to stay together to run. It looks like it will fit nicely into the stock location. I may have to adjust the column lower and build an trim ring around the cluster. |
Mike Bellis |
Oct 13 2012, 07:10 PM
The cool thing about the OBX (don't laugh) intake manifold is the ability to swap the throttle body to the front or rear. Right now it's setup on the rear. My AEM methanol injector is on the front. The shitty thing about the OBX manifold was the fuel rail. The one that came with the manifold is polished and the -6AN fittings arn't right. They do not fit a -6AN fitting. Shitty Chinese manufacturing. I just happened to have another OBX rail and it worked with a little modification. Aeromotive 75psi regulator is hanging on the end. Not sure I will leave it there but we'll see...
Here is the oil cooler attachment and Crankcase evacuation fitting visible. I removed the factory water cooled oil cooler and will run my -12AN oil cooler lines to it. (IMG:style_emoticons/default/smile.gif) I had to add a 45 elbow and -10 to -12 adapters. The elbow it for clearance between the -12 fittings only. |
Lo-Fi Version | Time is now: 24th April 2024 - 03:23 PM |
