Sasquatch Part III Audi 1.8t transplant..., PCV upgrades finally... |
Mike Bellis |
Jun 10 2012, 05:41 PM
I have A.D.D. I admit it. I also can't leave well enough alone. I got really motivated by Andrew Dalen and seeing a 914 with Subie power driving to WCR12 from Idaho. What a beautiful car...
I stumbled on a steal of a deal for a 2001 Passat 1.8t, Audi ATW engine and 5 speed transaxle. Long story short and here you go. New engine cleaned and ready for fab time. The exhaust and turbo have been removed before power washing. Here is a link to Part I http://www.914world.com/bbs2/index.php?act...=0#entry1396734 Part II http://www.914world.com/bbs2/index.php?showtopic=172455 Here is the challenge. The transaxle. Either I fab an adapter, Fab an axle to take 1 Porsche CV and 1 Audi/VW CV or Replace with Boxster tranny, that will: Bolt right on, Shifter is cheap and available and requires less fab time. I'm leaning to the Boxster due to the 100mm Porsche CV flange. The Audi is 114mm. This is whats left of the wiring after the car gets gutted. The ECU and gauge cluster have a symbiotic relationship. They work together and have to stay together to run. It looks like it will fit nicely into the stock location. I may have to adjust the column lower and build an trim ring around the cluster. |
okieflyr |
Oct 13 2012, 09:14 PM
9fauxteen Group: Members Posts: 816 Joined: 9-January 05 From: Phila PA Member No.: 3,426 Region Association: North East States |
Mike, have you checked your height and clearance with the OBX manifold yet ?
Are you going to use any rubber or material between the cradle and body? The cradle will hold and transfer alot of vibration to the body. I used stock 911 mounts at my four points of engine/ body mounting and it is very effective with the vibration. My engine lid will get excited for about 2 minutes when cold, but everthing is quiet beyond that. |
Lo-Fi Version | Time is now: 28th March 2024 - 06:40 AM |
