Cam Choices, Stock vs Stock |
Allan |
Oct 17 2004, 09:08 AM
Getting ready to buy a new cam so the motor can go back together. I'm going to replace it with a stock grind but was wondering about the difference in where you buy them from. Pelican has a stock webcam for $130.00, GPR sells an aftermarket or reground cam (their words) for $63.00. Differences? Recommendations? Thanks.
Cap'n Krusty |
Oct 17 2004, 09:16 AM
Having seen numerous failures of various supplier's reground cams and lifters over the years, I've settled on new cams and matching lifters from WebCam. The Cap'n
seanery |
Oct 17 2004, 09:17 AM
A cam can do lots to liven an engine.
I would ask Jake, Brad & others what they reccomend. Are you keeping the stock injection? Exhaust, etc...? |
Allan |
Oct 17 2004, 09:27 AM
Yes, everything will remain stock other than new euro spec P/C's.
Mueller |
Oct 17 2004, 09:36 AM
I'd offer Jake some sort of bribe and see if you could get a cam and lifters from him....even if it costs $50 or more than the vendors listed, it'll be well worth it......
Type 4 |
Oct 17 2004, 05:39 PM
Member Group: Members Posts: 412 Joined: 30-September 04 From: Costa Mesa Calif. Member No.: 2,866 |
You will also need the webcam lifters they sell them for $142 so you are looking at $272 not $130.
Jake Raby |
Oct 17 2004, 08:21 PM
Sure, I'll sell ya a cam..
Its not 50 bucks more either, really about 20 bucks more.. BUT, it's kick ass! |
Allan |
Oct 18 2004, 10:22 AM
Jake, will it work with my stock FI system? Is it install and go? I'm interested to learm more.
Jake Raby |
Oct 18 2004, 10:31 AM
Yes,
I have several cams that are stock FI compatible. These are actually made just for the system.. I own 43 cam grinds at web that are not in their catalog. I have a cam for any application, but need to know engine specifics before I can choose one for you. |
Allan |
Oct 18 2004, 11:39 AM
Just let me know the info you need and I will provide it.
Mueller |
Oct 18 2004, 11:49 AM
i'm guessing he wants to know:
motor size (bore and stroke if not stock), compression ratio, details on the heads, fuel injection used (not sure if he has a different cam for D-jet and L-jet) and intended use of the car....daily driver, auto-x'r only, track or ????? I'm guessing you need this car as a daily driver.... |
Allan |
Oct 18 2004, 12:02 PM
It's a stock '76 2.0 w/d-jet. Euro P/C's. Don't know what the compression ratio is. Heads, crank, rods, and cases are still at Rimco. Occasional driver.
Jake Raby |
Oct 18 2004, 01:06 PM
Valve sizes? Port work? Compression ratio? Gearing? Altitude/elevation??
Bleyseng |
Oct 18 2004, 02:04 PM
How about for a 96mm p&c's, 8.2to1 comp, valves are 42x38 ported heads, stockish gearing, sealevel, Djet FI also. Has dyno'd 95 rear wheel hp.
Geoff |
Bleyseng |
Oct 18 2004, 09:04 PM
Jake Raby |
Oct 18 2004, 09:15 PM
If you have 95HP now, you don't need any help, thats damn good.....
Bleyseng |
Oct 18 2004, 10:07 PM
shit, I was trying for 100hp and 500revs of power before it drops off.
Jake Raby |
Oct 18 2004, 11:28 PM
What cam does it have now??
Mueller |
Oct 18 2004, 11:33 PM
Jake, just for $hits and giggles, do you have a recommended camshaft for a bone stock 1.8 that is to have a small turbocharger installed for daily use?? (IMG:style_emoticons/default/smile.gif)
how much would it cost for parts to split a case to replace a cam? Would it be okay to re-use the crank and cam bearings? |
Bleyseng |
Oct 19 2004, 07:18 AM
Stock cam Jake. Idles like a kitten. Running SSI he's with a bursch as I have heat.
Thinking about raising the compression ratio. Thinking about those squisy pistons Thinking about more duration on the exhaust. Geoff (IMG:style_emoticons/default/wacko.gif) engines coming apart soon to fix whatever I broke overreving it |
Lo-Fi Version | Time is now: 15th May 2024 - 10:26 PM |
