2 Pages V < 1 2
> Cam Choices, Stock vs Stock
DNHunt
post Oct 19 2004, 07:28 AM
Post #21
914 Wizard? No way. I got too much to learn.
Jake
Geoff's the guy that figured out the firing order problem I had. He's bailed me out several times. Don't do too much for him though, I want to smoke his ass.
Dave
Jake Raby
post Oct 19 2004, 08:28 AM
Post #22
Engine Surgeon
If it has a stock cam, even though it has alot of power it is probably in a very narow band...
Adding a camshaft with a tad more compression will give better results...
I tested the Squishy pistons and they failed my testing....
I really think that you had good weather at that dyno the day you went! Not to take away from your engine but most of the time we barely see 100HP from that combo at the flywheel!
Bleyseng
post Oct 19 2004, 09:17 AM
Post #23
Aircooled Baby!
I have dyno'd that engine 3 times over a couple of years. Consistant 90-92hp on a roller dyno with one day hitting 95hp after doing a tuneup, valve adjustment, no aircleaner etc.
Most 2.0l barely hit 80hp on that roller dyno btw.
Just looking to have a flatter hp curve across a higher rpm range witha few more revs.
I'll look for a dyno chart.
What compression ratio you talking about? As I think I'll have to stick in new pistons as these might be toast.
This might be the time for me to go to Megasquirt if I go to a hotter cam. Wait I don't want a hotter cam I want something that keeps things cool! but more hp. (IMG:style_emoticons/default/wacko.gif)
Geoff
Jake Raby
post Oct 19 2004, 09:23 AM
Post #24
Engine Surgeon
The cam I would think about for you has 800 more revs of power and a flatter curve..
It has split lift and split duration and the intake profile is from a Honda motorcycle and exhaust is from a Chrysler Hemi....... its a great cam.
Bleyseng
post Oct 19 2004, 09:33 AM
Post #25
Aircooled Baby!
Ok, I'll order it from you. Do I need to call you ? I guess I'll have to go with the ceramic lifters too unless you have worked out the replacement steel ones.
Here is one of the dyno run charts.
Jake Raby
post Oct 19 2004, 09:52 AM
Post #26
Engine Surgeon
Are you going to leave the engine alone otherwise??? Just add CR??
Bleyseng
post Oct 19 2004, 10:04 AM
Post #27
Aircooled Baby!
New 96mm P&C's, new cam and lifters, same ported heads but maybe better valve springs plus any other suggestions.
Gonna stay with either djet or go to Megasquirt FI as I hate carbs in Seattle. BTDT
Geoff
Jake Raby
post Oct 19 2004, 10:16 AM
Post #28
Engine Surgeon
Cool, so you want to go with ceramic lifters??
seanery
post Oct 19 2004, 10:17 AM
Post #29
waiting to rebuild whitey!
Geoff,
get your butt over to the FFC, LN Engineering has donated a set of Ceramic Lifters! (IMG:style_emoticons/default/smilie_pokal.gif)
Jake Raby
post Oct 19 2004, 10:30 AM
Post #30
Engine Surgeon
And they are SUPER hard to find right now! We are hurting for them to keep our schedule up..
URY914
post Oct 19 2004, 11:14 AM
Post #31
I don't you to give out any trade secrets but who is making the lifters?
It must be a small specility shop right?
LN can't be doing these in house.
Paul
Jake Raby
post Oct 19 2004, 11:22 AM
Post #32
Engine Surgeon
Joe Schubeck makes them, actually he farms some of out to someone else that we cannot figure out..
Bleyseng
post Oct 19 2004, 02:10 PM
Post #33
Aircooled Baby!
Yes, I want to go with ceramic lifters.
I can't fly back to the FFC, no time due to work. (hehe I do work sometimes)
I am setting up a trip for New Years in Suriname thou.
Guess I better get on the list., Jake.
Geoff
Katmanken
post Oct 19 2004, 06:12 PM
Post #34
You haven't seen me if anybody asks...
Coors is one of the big US ceramic companies. Mebbe they make the lifters.
They make ceramic filters for their beer and ceramic parts for other folks - which is how they got into the business.
They injection mold the ceramic (like plastic) and then fire it. Had them make some parts for me once from a prototype plastic tool.
Parts came back at 40% mold original size. (IMG:style_emoticons/default/blink.gif)
Ceramics shrink like a bitch when fired. A lot more than metal injection molded parts (MIM) .
Spent some time talking with a Japanese company and they talked about a grinding process to get phenominal (SP?) tight tolerances. Had a rod in a lifter sized cylinder that was ( if my memory serves) about a half a thou clearance. Got their literature somewhere.
Ken
Mueller
post Oct 19 2004, 06:31 PM
Post #35
914 Freak!
getting the lifters manufactured is not a big deal, it's meeting the minimum quantity
I'd bet money it's this company that is making them for Schubeck:
Ceradyne
Kyocera also makes silicon nitride lifters for industrial uses..........
Mueller
post Oct 19 2004, 06:36 PM
Post #36
914 Freak!
from a Ceradyne sales page:
Mueller
post Oct 20 2004, 11:01 AM
Post #37
914 Freak!
Jake Raby
post Oct 20 2004, 11:03 AM
Post #38
Engine Surgeon
Already checked into that place.... Thats not who is doing them for Schubeck..
They require an order so big that we could never meet it.
Mueller
post Oct 20 2004, 11:11 AM
Post #39
914 Freak!
want me to look into a few companies that we use for ceramics??
I don;t have a lifter here at work, but it wouldn't be hard to just draw up a preliminary drawing for an RFQ.
Jake Raby
post Oct 20 2004, 11:14 AM
Post #40
Engine Surgeon
Sure, keep looking!
Its definately somewhere in California- we know that!
My new "Pro Extreme lifter" will be done in a few eeks for testing. It has a steel body and a rotating ceramic foot and allos valve events almost as fast as a full roller arrangement!
2 Pages V < 1 2
- Lo-Fi Version Time is now: 31st October 2024 - 05:11 PM
