Clutch adjustment instructions, from the 31 pages |
Dr Evil |
Jun 13 2012, 01:47 PM
Send me your transmission! Group: Members Posts: 22,995 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
From my 31 pages of trans notes:
*Clutch cable The clutch cable being too loose is probably one of the most common reasons that people’s shifting sucks. If your cable is too loose then you will not be able to fully disengage the pressure plate from the clutch disk and you will keep power to the transmission. If it is really loose then reverse will grind when shifting into it from a standstill. There is no way that this should happen if the clutch is fully disengaged. To properly adjust your clutch, you need to tighten the cable until the clutch disengages at about 1/4 to 1/3 pedal travel (See figure 1 in appendix). If the clutch disengages too early then it is too tight, too late then it is too loose. Attached image(s) |
JawjaPorsche |
Jan 14 2019, 06:56 PM
Advanced Member Group: Members Posts: 3,463 Joined: 23-July 11 From: Clayton, Georgia Member No.: 13,351 Region Association: South East States |
Most people use aluminum tubing and have seen people use several over sized nuts.
Yes it goes next to trunnion. |
Lo-Fi Version | Time is now: 17th May 2024 - 05:21 AM |
