How can you tell if you have flat cam lobes?, Strange lash issue |
tornik550 |
Jun 15 2012, 02:27 PM
Senior Member Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
I am paranoid of developing flat can lobes on my recent engine rebuild. I am paranoid cause I have heard so much crap about the cam that I used- scat c45. I am asking this more for curiosity sake. I had a strange issue but I am certain it's unrelated. I set my valves on cyl 1 to 0 lash (chromoly pushrods). I did that at tdc for that cyl. Te intake and exhaust valves. Seem to lift normally. The issue is that at a different point in the cycle (other than tdc or full lift) the valves are very loose. The valves go back to zero lash at TDC. The compression is actually about 5 points better on that cylander. I think it's possible that the rocker shaft bolts may have loosened a bit, however I've already removed them. It doesn't sound like a flat lobe to me.
Lo-Fi Version | Time is now: 18th May 2024 - 02:23 PM |
