Part needed help, Missing connector for rear sway bar. |
gregrobbins |
Oct 18 2004, 12:18 AM
Member: Team NARP Group: Members Posts: 1,515 Joined: 23-March 04 From: Arizona Member No.: 1,844 Region Association: Southwest Region |
I have a factory sway bar on my '74 2.0. This afternoon I was installing a set of headers and noticed that the rear sway bar is not attached to the right shock. The Ball is on the shock mount, but it appears a plastic piece that is on the left side that holds the bar to the shock mount is missing on the right side and drop bar is not attached.
I don't know what it is called or where to find a new one. Haynes calls it a grommet, but I don't find them mentioned on the bird. Can anyone point me in the right direction? Thanks (IMG:style_emoticons/default/wacko.gif) |
skline |
Oct 18 2004, 12:22 AM
Its a drop link bushing, Pelican does sell them. They are not easy to get installed however, Ask me how I know.
skline |
Oct 18 2004, 12:31 AM
You may need to call them to find out availability, but I know I got a set from them not too long ago.
rhodyguy |
Oct 18 2004, 07:21 AM
bird or gpr. chances are you need the whole set. when you go to put them in, put a little grease in the hole in the link, then heat the bushing up in some hot water. they go in, in opposite directions. ask me how i know. before you order, check the condition of the bushings in the front swaybar also.
kevin |
Lo-Fi Version | Time is now: 16th May 2024 - 07:03 AM |
