Master Cylinder - Electric Connection, This one's not like the other |
Rhodes71/914 |
Oct 19 2004, 05:13 PM
Glacier Group: Members Posts: 1,374 Joined: 8-August 04 From: End of the Road, Alaska Member No.: 2,482 |
Received my new 17mm master cylinder today but the question is why is there only a place for one electical connection, the one on the car now has 2 and 2 different wire to connect. What exactly does this do? What do i do with the wires.
Help, I'm sooo close to driving. Pic of old MC Attached image(s) |
lapuwali |
Oct 19 2004, 05:30 PM
They just hook to the warning light on the dash, so the light flashes at you when you press on the pedal when you have no brakes. This is assuming the fact that you'll not actually be stopping isn't telling you first...IMHO, a useless appendage, and I'd not let the lack of said wiring stand in the way of not driving the car.
sgomes |
Oct 19 2004, 06:33 PM
Electric Member Group: Members Posts: 815 Joined: 6-May 04 From: Campbell, CA Member No.: 2,029 |
You have two wires. Just hook the non-solid brown one to the single connector. I think it is brown with a black stripe??? Anywho, on the version with two connections, one is ground. On the version with one connection the grounding is done through the case of the MC itself.
Rhodes71/914 |
Oct 19 2004, 06:44 PM
Thank You Shannon.
Brakes going back together tonight. |
Lo-Fi Version | Time is now: 20th May 2024 - 10:39 PM |
