Charcoal Canister Mounting |
ChrisVCR |
Jul 1 2012, 09:54 PM
Newbie Group: Members Posts: 13 Joined: 3-April 12 From: Charlotte, NC Member No.: 14,335 Region Association: None |
Hoping to find some pics of stock 1.8 L-Jet motors so I could see how the canister is mounted. Mine is hanging loose inside the engine bay. It's connected and functioning but is just sitting loose. Any ideas or pics of how it should be properly mounted?
Thanks! |
zonedoubt |
Jul 2 2012, 12:03 AM
Canadian Member Group: Members Posts: 668 Joined: 14-May 03 From: Vancouver, BC Member No.: 696 Region Association: Canada |
If it's a '75, then it hangs off the side of the battery tray. There's a few good threads with photos on this topic. Search is your friend.
http://www.914world.com/bbs2/index.phps=&a...t&p=1090943 |
ChrisVCR |
Jul 2 2012, 06:47 AM
If it's a '75, then it hangs off the side of the battery tray. There's a few good threads with photos on this topic. Search is your friend. http://www.914world.com/bbs2/index.phps=&a...t&p=1090943 I should have put that mine is a '74. I did do some searching first (I hate to get flamed) but was unable to find a nice stock motor pic. so was reaching out. I'll keep searching. Was '74 mounted the same way as the 75? |
jim_hoyland |
Jul 2 2012, 07:38 AM
Get that VIN ? Group: Members Posts: 9,291 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
My '75 was originally attached to the battery tray hold down bolt with the bracket pictured below... (IMG:style_emoticons/default/smile.gif)
JFJ914 |
Jul 2 2012, 09:21 AM
Senior Member Group: Benefactors Posts: 813 Joined: 13-June 03 From: Alpharetta, GA Member No.: 814 Region Association: South East States |
If it's a '75, then it hangs off the side of the battery tray. There's a few good threads with photos on this topic. Search is your friend. http://www.914world.com/bbs2/index.phps=&a...t&p=1090943 I should have put that mine is a '74. I did do some searching first (I hate to get flamed) but was unable to find a nice stock motor pic. so was reaching out. I'll keep searching. Was '74 mounted the same way as the 75? It depends, mine 4742912244, has it mounted on the back passenger(Trunk) wall on a welded stud. Some later ones had it mounted on the battery tray. |
zonedoubt |
Jul 2 2012, 11:58 AM
Lo-Fi Version | Time is now: 15th May 2024 - 07:37 AM |
