Shifter vibration, Whats the cause... |
2-OH! |
Oct 20 2004, 01:20 PM
Senior Member Group: Members Posts: 552 Joined: 17-October 03 From: Santa Clarita, Kalifornication Member No.: 1,253 |
My shift lever in the 75 is vibrating at certain RPM's ...What's worn out and causing the problem...Is something lose or worn or both under the shifter...
New bushings in the back and at the firewall... 2-OH! |
tdgray |
Oct 20 2004, 01:22 PM
Thank God Nemo is not here to see this Group: Members Posts: 9,705 Joined: 5-August 03 From: Akron, OH Member No.: 984 Region Association: None |
Just your shifter is vibrating.... lucky you (IMG:style_emoticons/default/biggrin.gif)
I know wise ass - sorry can't help with the problem. |
RustyWa |
Oct 20 2004, 01:25 PM
Working Member Group: Members Posts: 610 Joined: 2-January 03 From: Kent, WA Member No.: 72 |
I chased mine for a while. I checked and fixed all the usual suspects to no avail. It turned out to be the nut on my inside rear trailing arm was slightly loose.
dmenche914 |
Oct 20 2004, 02:15 PM
Senior Member Group: Members Posts: 1,212 Joined: 27-February 03 From: California Member No.: 366 |
worn tranny or motor mounts can cause excessive vibration, so check the rubber mounts ont he tranny tail, and on the motor mount cross bar. You are ont he right track with new bushings also.
dave |
Lo-Fi Version | Time is now: 16th May 2024 - 02:26 PM |
