Okay you transmisson guys, what's my problem |
ws91420 |
Oct 20 2004, 01:45 PM
Yes I have one a Lensley 914 Group: Members Posts: 2,063 Joined: 10-September 03 From: Ruther Glen,VA (halfway between sticks and civilization) Member No.: 1,137 Region Association: MidAtlantic Region |
My trans input shaft won't turn. I took off the rear cover and when I removed the the double reversing gear (Porsche manual label) it turns freely. Do I need to go deeper into trans? What could possibly cause this?
ClayPerrine |
Oct 20 2004, 01:53 PM
Make sure that it is not in 2 gears at once. Pull the shifter console if it's a side shifter and make sure that the notches in the 3 shift rods are all lined up in the middle. If you have a tailshifter you can pull the fork and do the same thing.
bondo |
Oct 20 2004, 01:54 PM
I don't know if I count as a transmission guy, but I'll try and help (IMG:style_emoticons/default/smile.gif) I'm assuming you took off the gear that has two sets of teeth on it but is on a separate shaft than the rest of the gears, and comes off when you take off the tail cover. This gear could only affect things if reverse is somehow engaged at least a little bit. Check the first/reverse shift fork, if the bolt is missing or loose it could cause the problem. What is the history of the trans? Did it work and suddenly stop, or are you reassembling after a rebuild and finding a problem? The transmission will lock up if any two gears are engaged at once, and that would be my first guess. Investigate the shifter, and shift rods. Let us know what you find.
Bleyseng |
Oct 20 2004, 02:20 PM
Gotta be two gears at once sooo since you took off the rear cover its first/rev and another gear.
Geoff (IMG:style_emoticons/default/biggrin.gif) |
Red-Beard |
Oct 20 2004, 05:23 PM
"Ya canna change the laws of Physics" Group: Benefactors Posts: 1,124 Joined: 11-February 03 From: Houston, TX Member No.: 288 Region Association: None |
Ditto on 2 gears selected at once. Obviously 1st/rev and something else.
Lo-Fi Version | Time is now: 16th May 2024 - 02:21 PM |
