GT rockers to GT flare, Reshaping rockers, what looks best, need photos. |
ruby914 |
Jul 4 2012, 03:28 PM
Senior Member Group: Members Posts: 720 Joined: 26-April 09 From: Hawthorne, Ca Member No.: 10,305 Region Association: None |
I got some budget rockers that (IMG:style_emoticons/default/barf.gif) needed lots of work.
First cut about 1" off the top and had to add 3/4" to the bottom. Cut about 1/4 off the front but I still don't like how it flares out different than the body lines. On the bottom of the door there is a bevel in the body that the rocker follows until it flares out. At that point the rocker flares as much as the body, not staying set in as much as the bevel. I am thinking it would look better If the rocker didn't flare out so much. Is that clear? I would like to see how others have handled this trasition. Attached image(s) |
3d914 |
Jul 6 2012, 06:38 PM
Senior Member Group: Members Posts: 1,275 Joined: 24-September 03 From: Benson, AZ Member No.: 1,191 Region Association: Southwest Region |
Here's a 914-6 in progress so we can see better. Hopefully the owners will stumble onto this thread and add details.
The rocker is set close to the base of the chamfer in the body - yet still results in a slight gap at the flares. My fitting tests indicate this is related to the downward angle of the flares. The larger the angle from vertical - the more obvious the gap. Same at the back. One at the rear. And finally the opposite side. |
Lo-Fi Version | Time is now: 19th May 2024 - 07:43 PM |
