Easy question... |
Easy question... |
MikeM |
Jul 10 2012, 11:36 AM
Senior Member Group: Members Posts: 564 Joined: 16-May 10 From: Calgary, Canada Member No.: 11,733 Region Association: Canada |
Hi all...just double checking. Transmission drain and fill plugs are 17mm hex?
Thanks, Mike |
bdstone914 |
Jul 10 2012, 11:40 AM
bdstone914 Group: Members Posts: 4,523 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
MikeM |
Jul 10 2012, 11:49 AM
Thanks...
type47 |
Jul 10 2012, 11:53 AM
Common suggestion is to remove the fill plug first then the drain. It'd be a shame to drain the fluid and not be able to refill 'cause you can't get the fill plug out (IMG:style_emoticons/default/blink.gif)
Lo-Fi Version | Time is now: 21st May 2024 - 12:02 PM |
