FS: great rear calipers, SOLD! Thanks |
lotus_65 |
Jul 10 2012, 03:22 PM
Senior Member Group: Members Posts: 1,608 Joined: 21-March 05 From: minneapolis, mn Member No.: 3,795 Region Association: Northstar Region |
SOLD
Admin, please delete. I just renewed some early rear calipers. The only difference between early ones and late ones are the two bleeders on the late ones, one on the early. No performance difference at all, according to Eric @ PMB. I polished and honed the pistons and cylinders, checked & replaced bad seals and lubed parking brake gearing & installed new pads. I also replaced the bad plugs with new 5mm plugs on the inner adjuster access so there'll be no more stripped plugs. I drove with these for about 300 miles, then swapped them for another set. They worked perfectly. $150.00 (The brake line in the pic isn't included) Thanks Paul |
lotus_65 |
Jul 13 2012, 04:09 PM
Lo-Fi Version | Time is now: 9th May 2024 - 04:51 PM |
