The white 74 - restoration/ 6 conversion, ? - 2056 - 2.7 w/CIS - 2.7 w/dual carbs - finally a 3.2 |
JStroud |
Jul 10 2012, 08:22 PM
Senior Member Group: Members Posts: 1,463 Joined: 15-January 11 From: Galt, California Member No.: 12,594 Region Association: Northern California |
I started a restoration thread for theYellow 75
And the New car thread when I bought the white 74. But since the yellow project has been put on hold, I guess I need a white 74 restoration thread, So here we go... Here are some pictures of the car when I first bought it last November. At least the lights all work! That doesn't look good The first month it spent on jackstands while I worked on the engine and brakes to get it driveable and able to be registered. Put in some new used seats, a dash mat, some carpet pieces and floor mats, a stereo and speakers, a new steering wheel, and fixed the odometer. After months of driving/working/driving/working, replaced the AAR - twice, the MPS - 3 times, decel valve -once, McMark adjusted my valves, sealed the tranny, replaced the cracked windshield, and drilled/taped and plugged 3 leaking galley plugs, that was a long day, ya McMark (IMG:style_emoticons/default/beerchug.gif) . Well I finally got it looking and running fairly well, been driving the piss out of it, almost 8K miles since december. Drove it to WCR (IMG:style_emoticons/default/driving.gif) My car on Laguna Seca Drove it in an autocross school, and two AX races. (IMG:style_emoticons/default/first.gif) (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/lol-2.gif) But now it's time for big changes, I had built (McMark) this 2056 for the yellow car. And it's been sitting on my workbench since December waiting for the yellow car to be ready. The yellow car's going to be a while..... So I decided to put it in the white car instead, but not only that, the D-jet system on the car now has been a pain (IMG:style_emoticons/default/headbang.gif) to sort out and its taken 3 complete systems to finally get it running this good, still needs a better MPS. So I pulled the trigger and bought a crankfire-Microsquirt FI system from McMark at Original Customs. Here's part of it No more distributor, no more obsolete FI parts, and tuning with my laptop how cool is that. (IMG:style_emoticons/default/aktion035.gif) Thats almost caught up....more to come Jeff |
JimN73 |
Jul 10 2012, 10:37 PM
Senior Member Group: Members Posts: 535 Joined: 6-October 07 From: Gig Harbor Member No.: 8,192 Region Association: Pacific Northwest |
Jeff, what's the configuration of your 2056? I built mine to a 2056 about a year and a half ago and Mark will be working on my MS & distributorless ignition kit as soon as he gets a couple of other projects done.
I'll have a thread when we get closer. Thanks, |
JStroud |
Jul 10 2012, 11:13 PM
Jeff, what's the configuration of your 2056? I built mine to a 2056 about a year and a half ago and Mark will be working on my MS & distributorless ignition kit as soon as he gets a couple of other projects done. I'll have a thread when we get closer. Thanks, Hey Jim, I had all my machine work done by HP machine in Lodi. I bought the KB pistons, had my stock cylinders bored. I also bought the 9550 super cam kit from Jake. The heads were totally rebuilt, ports polished, new seats and valves. All chambers were balanced, all rotating parts were balanced. Then I took it all to McMark and he built it and broke it in, I think he said 9.1-1 cr. Can't wait to drive it. Jeff |
JimN73 |
Jul 12 2012, 02:46 PM
Jeff, what's the configuration of your 2056? I built mine to a 2056 about a year and a half ago and Mark will be working on my MS & distributorless ignition kit as soon as he gets a couple of other projects done. I'll have a thread when we get closer. Thanks, Hey Jim, I had all my machine work done by HP machine in Lodi. I bought the KB pistons, had my stock cylinders bored. I also bought the 9550 super cam kit from Jake. The heads were totally rebuilt, ports polished, new seats and valves. All chambers were balanced, all rotating parts were balanced. Then I took it all to McMark and he built it and broke it in, I think he said 9.1-1 cr. Can't wait to drive it. Jeff I'm using Jake's 9530 cam with compression at 9.5:1 and lightened flywheel. Should be pretty comparable, performance wise but they'll tune differently. |
JStroud |
Jul 12 2012, 07:56 PM
I'm using Jake's 9530 cam with compression at 9.5:1 and lightened flywheel. Should be pretty comparable, performance wise but they'll tune differently. Jim, Rich Wilner has the same setup from McMark in his car, he posted his tuning file in his Microsquirt conversion thread, his file should get both of ours tuned fairly close to get started, thanks Rich. Should be a fun set up, actually getting excited about pulling a perfectly good running motor, but it will go in the yellow car someday. (IMG:style_emoticons/default/driving.gif) Jeff |
JimN73 |
Jul 12 2012, 09:03 PM
I'm using Jake's 9530 cam with compression at 9.5:1 and lightened flywheel. Should be pretty comparable, performance wise but they'll tune differently. Jim, Rich Wilner has the same setup from McMark in his car, he posted his tuning file in his Microsquirt conversion thread, his file should get both of ours tuned fairly close to get started, thanks Rich. Should be a fun set up, actually getting excited about pulling a perfectly good running motor, but it will go in the yellow car someday. (IMG:style_emoticons/default/driving.gif) Jeff Jeff, I've tried to open the zip file that he posted on April 24. It appears to be empty, unless I need another program to open it. I think you're right, we should be able to get our cars up and running quickly using information from those who have already done this. What's you schedule? I drive the car every day so I want to get all of the pieces & software together and get parts installed and tuning 99% done in 2-3 days. Mark is going to help with the install, so I'll have a good source for help. Jim |
Lo-Fi Version | Time is now: 16th May 2024 - 11:29 AM |
