The white 74 - restoration/ 6 conversion, ? - 2056 - 2.7 w/CIS - 2.7 w/dual carbs - finally a 3.2 |
JStroud |
Jul 10 2012, 08:22 PM
Senior Member Group: Members Posts: 1,463 Joined: 15-January 11 From: Galt, California Member No.: 12,594 Region Association: Northern California |
I started a restoration thread for theYellow 75
And the New car thread when I bought the white 74. But since the yellow project has been put on hold, I guess I need a white 74 restoration thread, So here we go... Here are some pictures of the car when I first bought it last November. At least the lights all work! That doesn't look good The first month it spent on jackstands while I worked on the engine and brakes to get it driveable and able to be registered. Put in some new used seats, a dash mat, some carpet pieces and floor mats, a stereo and speakers, a new steering wheel, and fixed the odometer. After months of driving/working/driving/working, replaced the AAR - twice, the MPS - 3 times, decel valve -once, McMark adjusted my valves, sealed the tranny, replaced the cracked windshield, and drilled/taped and plugged 3 leaking galley plugs, that was a long day, ya McMark (IMG:style_emoticons/default/beerchug.gif) . Well I finally got it looking and running fairly well, been driving the piss out of it, almost 8K miles since december. Drove it to WCR (IMG:style_emoticons/default/driving.gif) My car on Laguna Seca Drove it in an autocross school, and two AX races. (IMG:style_emoticons/default/first.gif) (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/lol-2.gif) But now it's time for big changes, I had built (McMark) this 2056 for the yellow car. And it's been sitting on my workbench since December waiting for the yellow car to be ready. The yellow car's going to be a while..... So I decided to put it in the white car instead, but not only that, the D-jet system on the car now has been a pain (IMG:style_emoticons/default/headbang.gif) to sort out and its taken 3 complete systems to finally get it running this good, still needs a better MPS. So I pulled the trigger and bought a crankfire-Microsquirt FI system from McMark at Original Customs. Here's part of it No more distributor, no more obsolete FI parts, and tuning with my laptop how cool is that. (IMG:style_emoticons/default/aktion035.gif) Thats almost caught up....more to come Jeff |
JStroud |
Mar 21 2015, 09:14 AM
About a month ago, after about a month of research, I started the electrical changes for the 3.2. I took the intake off, and modified the engine harness for the 914.
Rewired the 14 pin connector with one that will plug in to the cars 14 pin connector and eliminate the relay board. I had been going back and forth on where to mount the DME, finally after changing my mind several times I decided to mount it in the rear trunk. Quicker, easier, and I don't use the rear trunk much anyway. A couple of weeks ago I got a mounting plate made and welded some mounting studs. Plate is mounted with rubber offsets. The DME and harness installed. Then I took the wiring harness I pulled out of the red parts car and cut out enough wires to run the electrical from the DME harness to the under dash connections and fuel pump. I've got the interior apart ready to start that phase of the electrical, might have time this weekend to do more....we'll see |
Lo-Fi Version | Time is now: 15th May 2024 - 10:21 PM |
