The white 74 - restoration/ 6 conversion, ? - 2056 - 2.7 w/CIS - 2.7 w/dual carbs - finally a 3.2 |
JStroud |
Mar 21 2015, 09:45 AM
Senior Member Group: Members Posts: 1,463 Joined: 15-January 11 From: Galt, California Member No.: 12,594 Region Association: Northern California |
OK...almost there, Last week I got the tube with -AN fitting welded on from McMark, to modify my oil cooler. I cut the existing tube and mount, and fit the new tube on, ready to weld.
I had bought a new ring gear adapter and stage II clutch and pressure plate from KEP, I was planning on reusing the flywheel from the engine. I took the flywheel and clutch parts to my machinist to surface the flywheel and then balance it all, I also dropped off the oil cooler to be welded. Got a call yesterday.......flywheel is too worn to surface... (IMG:style_emoticons/default/headbang.gif) But the oil cooler is welded..... So I ordered a new flywheel yesterday (IMG:style_emoticons/default/w00t.gif) now when it comes in I just need to get it all balanced....and pick up the oil cooler. Well the threads caught up, now I need to get busy.... really like to drive it to WCR in April..... (IMG:style_emoticons/default/driving.gif) |
McMark |
Mar 21 2015, 11:15 AM
Glad you updated your thread. You right. A lot has happened... (IMG:style_emoticons/default/blink.gif)
steuspeed |
Mar 21 2015, 11:33 AM
Senior Member Group: Members Posts: 1,005 Joined: 12-July 11 From: Portland, Oregon Member No.: 13,308 Region Association: Pacific Northwest |
Do you still have those 14" Dunlops? I bought the last set of those tires from Tire Rack 195/55/15. I'm pretty happy with them, but the smaller diameter means more shifting and higher revs on the freeway. The ride is more supple than the P6000's I had before, but turn-in is not as crisp. I feel the compound is more sticky though.
JStroud |
Mar 21 2015, 01:06 PM
Glad you updated your thread. You right. A lot has happened... (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/lol-2.gif) Yep lots of changes.....over a couple years.... Yes I'm still running the same tires, really like them in the summer around town, but when it's cold or too wet not so much. Rev's were too high on my trip driving straight freeway, but I've fixed that with a set of 7 X 16's sitting in my shop waiting for tires. |
arkitect |
Mar 23 2015, 09:03 PM
Senior Member Group: Members Posts: 617 Joined: 3-March 10 From: Stockton, CA Member No.: 11,426 Region Association: None |
Jeff,
Lots of work done...almost there. Your a jack of all trades...very talented. Can't wait to see it done and you on the road again. Dave |
Cairo94507 |
Mar 24 2015, 06:57 AM
Michael Group: Members Posts: 9,708 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
Wow! That is a ton of work and I am impressed with all of it.
JStroud |
Mar 26 2015, 08:56 PM
Thanks Dave and Michael, its been fun, if my health hadn't taken a turn for the worse at the end of last year it would have been done by now. Finally doing better so should be soon, its been down since the middle of June last year....can't wait to drive it again.
Now for an update: Got my wire harness roughed out and labeled. Routed it through the firewall into the cabin. Now I just need to install the connectors in the engine compartment. Still need to finish routing it through the tunnel then I'm installing a new separate fuse block under the dash to hook up the start/run power for the DME, fuel pump, radio, aftermarket fog lights, and other accessories. I've also incorporated my center console gauge wiring into the harness. Changed the rubber fuel lines on the intake, cut off the crimped connectors, and installed the new fuel hose with FI hose clamps. Then I finally found a good deal on a rennshifter....thanks Bob....this is an upgrade I've been wanting to do. Should get my flywheel and clutch back all balanced tomorrow, and my oil cooler all welded up. (IMG:style_emoticons/default/piratenanner.gif) That should get things moving along. |
Erben914 |
Mar 26 2015, 10:53 PM
Member Group: Members Posts: 137 Joined: 1-January 13 From: Sacramento Member No.: 15,314 Region Association: Central California |
Very nice Jeff. That shifter looks sweet!
JStroud |
Mar 28 2015, 11:44 PM
JStroud |
Mar 28 2015, 11:51 PM
Went to the breakfast this morning, but manage to get a couple of hours in the shop.
Got setup to install the harness connectors. Got the female 14 pin connector on the car harness, and a 2 pin connector on the center gauge wiring for the oil temp and pressure. |
JStroud |
Mar 30 2015, 08:24 AM
We had our granddaughter for the weekend, but managed to get a couple hours in the shop yesterday. Installed a fuse block in the engine compartment for all the red wires connecting to the battery, never liked that setup, also needed 12v for the DME.
Now all my circuits will be fuse protected, wether they need it or not. |
JStroud |
May 31 2015, 12:42 PM
Had a setback getting my car done, my health took a turn for the worse and can't do much myself anymore. McMark came over and worked a couple of days in my shop and got the engine in the car, then he took the car to his shop and finished the installation. Thanks Mark, you're a good friend!!! (IMG:style_emoticons/default/wub.gif)
So my car is now mechanically done and runs awesome. I've been able to take it for a few short drives and am very impressed with the 3.2. (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/piratenanner.gif) I thought the 2.7 was fun, the 3.2 is amazing...so much power, definitely a great engine for these cars. He also got my new renn shifter installed, loving that too. Now I need to upgrade the rest of the linkage back to the tranny. 3.2 in the car Next I'm going to get the 16 X 7 Fuchs on the car, new tires should be here on Tuesday. I also ordered new bumper tops from 914rubber I have a set of early bumpers (no tits) I'm prepping for paint, then new tops. Cars running great now time to get it looking the way I've wanted. |
JStroud |
Jul 19 2015, 01:11 PM
Yesterday Mike Bellis and Andyrew came by to help me get my 16 X 7 fuchs on the car, I bought these about 2 years ago from Jamie, about time I got them on the car.
Mike and Andyrew rolled the rear fenders until they finally fit, (IMG:style_emoticons/default/smash.gif) not too much pulling needed. I sure do like the way they look on the car. Getting started All done Andyrew decided to do some body work while he was there, he pounded out the small dent on the early front bumper I had, then welded up the license plate holes, and the holes in the rear bumper. (IMG:style_emoticons/default/welder.gif) Then he got all the welded holes grinded down, skim coated the front bumper, and sanded. A light sanding and paint and the bumpers will be done. A big thanks to Mike and Andyrew, (IMG:style_emoticons/default/beerchug.gif) you guys are awesome, can't believe all you got done in just a few hours. Can't thank you enough for all your help. Cars almost done now. (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/piratenanner.gif) Jeff |
Chris H. |
Jul 19 2015, 01:32 PM
Senior Member Group: Members Posts: 4,027 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
Nice work guys! Those wheels look PERFECT! Can't even tell you pulled the rear fenders.
Hey Jeff, do you have a 6 badge for that thing? If not I'd like to send you this one: I was gonna put it on my car but I'd rather get a 3.3 badge made instead. RJMIII did these a while back. You could either leave it polished aluminum (it's silver, not gold) or paint/plasti-dip it black. It'd go great with the theme either way. It's the exact size of the original one. Just PM me your address if you want it. |
JRust |
Jul 19 2015, 01:39 PM
914 Guru Group: Members Posts: 6,305 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
Wheels look great Jeff! Absolutely my favorite look & wheels. 16" fuchs with black centers & polished lips. Congrats on getting the car closer to done. The work on your bumpers will really shine when you paint them. Always great having nice straight stuff. Looking forward to seeing those bumpers done & back on your car. Wish I could have made it down to help. Looking great bud
turk22 |
Jul 19 2015, 04:45 PM
Treetop Flyer Group: Members Posts: 735 Joined: 27-July 12 From: Cincinnati OH Member No.: 14,725 Region Association: Upper MidWest |
Yesterday Mike Bellis and Andyrew came by to help me get my 16 X 7 fuchs on the car, I bought these about 2 years ago from Jamie, about time I got them on the car. Mike and Andyrew rolled the rear fenders until they finally fit, (IMG:style_emoticons/default/smash.gif) not too much pulling needed. I sure do like the way they look on the car. Getting started All done Andyrew decided to do some body work while he was there, he pounded out the small dent on the early front bumper I had, then welded up the license plate holes, and the holes in the rear bumper. (IMG:style_emoticons/default/welder.gif) Then he got all the welded holes grinded down, skim coated the front bumper, and sanded. A light sanding and paint and the bumpers will be done. A big thanks to Mike and Andyrew, (IMG:style_emoticons/default/beerchug.gif) you guys are awesome, can't believe all you got done in just a few hours. Can't thank you enough for all your help. Cars almost done now. (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/piratenanner.gif) Jeff Love to hear these stories, its a great community we have here! Great work! (IMG:style_emoticons/default/beerchug.gif) |
jeeperjohn56 |
Jul 19 2015, 05:19 PM
Member Group: Members Posts: 479 Joined: 9-July 06 From: Antioch,Ca. Member No.: 6,407 Region Association: None |
Hey Jeff, glad to hear you getting car done, I;m in the same boat as you need to get rear window resealed install new interior, new rear shocks, but need to clean garage so I can work on car, keep it up. John (IMG:style_emoticons/default/driving.gif)
Mike Bellis |
Jul 19 2015, 05:28 PM
We had fun and good conversation. Let me know if you need anything else. (IMG:style_emoticons/default/beerchug.gif)
JStroud |
Jul 20 2015, 07:26 PM
Thanks guys, this is the fun part, finishing up the last few items.
Appreciate the offer Chris, and yes this is a great group of people, all the help and words of encouragement has been overwhelming....thanks everyone. Get your car done John, love to see it on the road. Ordered the paint for the bumpers today....one step closer. Jeff |
brant |
Jul 20 2015, 07:38 PM
914 Wizard Group: Members Posts: 11,611 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
looks GREAT Jeff!
Lo-Fi Version | Time is now: 23rd April 2024 - 02:32 AM |
