reman fuel injectors |
partwerks |
Jul 13 2012, 09:50 PM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
I did some searching online to see if remanufactured fuel injectors are ok to get and got some responses both ways??
http://www.ehow.com/how_4453138_buy-remanu...-injectors.html http://www.rockauto.com/catalog/x,carcode,...1,parttype,6224 Never had any problem starting it after the re-flash over 4 months ago, with the exception of recently when the fuel pump died and we now replaced it, but after that it had a bit of hesitation going from first to second. After warming up and trying to restart it, it didn't want to start again. Of his two choices, I'm leaning more towards it needing fuel injectors as opposed to the reflash, since it never acted up before?? It has about 40,000 miles on the engine. He says: Lyle, after your car sat a few hours and cooled down it started fine, there is one of two things going on, 1 your fuel injectors are bad and bleeding fuel through hot soak. 2 your programmer is messing things up. I want to put in new spark plugs and flash your computer back to stock. |
cary |
Jul 13 2012, 10:13 PM
I did the GB rebuild from Rockauto.
So far so good. Do a Google on GB. Looks like a pretty impressive operation. |
toadman |
Jul 14 2012, 04:56 PM
Member Group: Members Posts: 168 Joined: 26-December 05 From: Cincinnati, OH Member No.: 5,316 |
I did some searching online to see if remanufactured fuel injectors are ok to get and got some responses both ways?? http://www.ehow.com/how_4453138_buy-remanu...-injectors.html http://www.rockauto.com/catalog/x,carcode,...1,parttype,6224 Never had any problem starting it after the re-flash over 4 months ago, with the exception of recently when the fuel pump died and we now replaced it, but after that it had a bit of hesitation going from first to second. After warming up and trying to restart it, it didn't want to start again. Of his two choices, I'm leaning more towards it needing fuel injectors as opposed to the reflash, since it never acted up before?? It has about 40,000 miles on the engine. He says: Lyle, after your car sat a few hours and cooled down it started fine, there is one of two things going on, 1 your fuel injectors are bad and bleeding fuel through hot soak. 2 your programmer is messing things up. I want to put in new spark plugs and flash your computer back to stock. Are you saying that there is someone that will "reflash" our 30+ yr. old fuel injection ECUs? If so, I would like more information about that, please. I have a 1976 car with stock EFI but I have removed all the smog stuff and the decel valve. I sometimes have a problem restarting when the engine is really hot. I am able to start it if I put the gas pedal almost to floor and crank the starter. When it does start the idle is low and I have to depress the gas pedal slightly to keep the oil pressure up. All of the fuel injection components check out OK electrically, though, so I am stumped and have just been living with it. |
ape914 |
Jul 14 2012, 08:39 PM
red locktite Group: Retired Members Posts: 240 Joined: 7-February 11 From: In front of a computer Member No.: 12,676 Region Association: None |
What's a "re-flash"?
Dustin |
Jul 15 2012, 02:20 PM
Member Group: Members Posts: 111 Joined: 19-August 10 From: Woodland Hills, CA Member No.: 12,072 Region Association: None |
reflash = software update on to flashable ROMs.
I don't think anybody is flashing anything on a 914. |
RON S. |
Jul 15 2012, 03:29 PM
9140430841, FINALLY RUNNING Group: Members Posts: 1,212 Joined: 22-May 03 From: WALTERBORO,S.C. Member No.: 724 Region Association: South East States |
I did a few cars' fuel injectors by way of GB at Rockauto. GB is a nationally renowned injector remanufacturer. Supposedly they take them apart and ultrasonically clean them, then flow check them. I've usually had it done during rebuilds. Even had to do it once when I'd left a car sit for a year or so with out starting it. Crappy gas locked them right up, and they wouldn't fire. 30 bucks or so per injector, if I recall. Ron |
Lo-Fi Version | Time is now: 20th May 2024 - 08:10 PM |
