Can I make a Master Key from Valet Key? |
skaufmann |
Jul 18 2012, 12:36 PM
Blissfully Ignorant Group: Members Posts: 103 Joined: 26-May 11 From: San Diego - College Area Member No.: 13,123 Region Association: Southern California |
I only have the original Valet key that turns the ignition. I have a 2nd key (Master) that opens the passenger door (and nothing else) and a 3rd key (Valet) that open the driver door (and nothing else).
From what I can gather, the only difference between the master key and the valet key is the channeling down the side of the key, not the notch/tooth profile. If I'm correct, can I make a copy of the original Valet key to a new Master key? My thought is it's easier to rekey the door locks and I suspect the new Master will then work the trunk and glove box since those were not likely replaced like the door locks were. |
Jul 18 2012, 12:46 PM
You should be able to use the valet key to make a master that will run the ignition.
It sounds like someone has already swapped out the door lock assemblies, thus why you have two keys. You will most likely have to re-key all the locks to match the new master key. Its not a hard project, just time consuming. rich |
skaufmann |
Jul 18 2012, 12:51 PM
You should be able to use the valet key to make a master that will run the ignition. It sounds like someone has already swapped out the door lock assemblies, thus why you have two keys. You will most likely have to re-key all the locks to match the new master key. Its not a hard project, just time consuming. rich Perfect thanks! Yeah exactly what I was expecting. I'm making a fairly safe assumption that the ignition valet key I have is original as the ignition is painful and expensive to replace. The door locks with their known issues were more likely replaced back in the day (car was sitting for 10 years before I got it) and not rekeyed. I'm unable to test the grove box and trunks but I'm suspecting they match the ignition tooth profile but Master only. |
Jul 18 2012, 01:02 PM
If I recall correctly, the glove box and front trunk are the only ones that the master key protects...
May also be the rear trunk, but I have never found that to be true. BUT None of my cars where ever keyed correctly...so I have been chasing the keys forever anyways. Re-keying a lock may have a classic thread that someone did...I seem to recall McMark did one. If you have enough parts, you can rekey all the locks to match the new key...they are just tumbers that get replaced with the key in the tumbler...keep swapping them out until they all sit flush with the tumbler housing. you should be able to buy the correct blank master keys from George Hussey at Auto Atlanta... If not, there is a key guy that shows up at Hershey every year who only does these keys.... you should be able to find him at Pelican Parts, or possibly the Samba. Also, I believe the Porsche dealer has the proper blank keys. Rich |
markb |
Jul 18 2012, 01:10 PM
GPR sells originals & repros of the keys. Take the best key you have, and rekey everything to that key. Most places that make keys can make the copies. My local Ace hardware does them for me. Follow the rekey thread (it's in my signature) and do the rest of them. If you take the glove box lock out & use those wafers for the spares, then key the ignition, doors, rear trunk, front trunk then the glove box, in that order, you should come pretty close. If you need some extra wafers, at least the exterior stuff is done, so you can drive the car while you source the extras.
skaufmann |
Jul 18 2012, 02:39 PM
Awesome help guys!
Is there a source for wafers or am I looking to get them from other salvaged tumblers only? |
markb |
Jul 18 2012, 02:48 PM
Awesome help guys! Is there a source for wafers or am I looking to get them from other salvaged tumblers only? Nobody has found a source, other than robbing them. I have extras if you wind up needing them. It's hard to just send an assortment, not knowing what you'll need. That's why I suggest doing what you can with what you have, then at least you've narrowed down what you'll need to finish. |
barefoot |
Jun 27 2013, 08:02 AM
Senior Member Group: Members Posts: 1,274 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
Awesome help guys! Is there a source for wafers or am I looking to get them from other salvaged tumblers only? Nobody has found a source, other than robbing them. I have extras if you wind up needing them. It's hard to just send an assortment, not knowing what you'll need. That's why I suggest doing what you can with what you have, then at least you've narrowed down what you'll need to finish. Tweet now sells new wafers |
doug_b_928 |
Feb 18 2017, 08:19 PM
Senior Member Group: Members Posts: 692 Joined: 17-January 13 From: Winnipeg Member No.: 15,382 Region Association: Canada |
My car only came with a valet key. Reading on the classic thread, it seems the only difference is the valet key has an additional slot running the length of the key (that interacts with the 'valet wafer' so that it won't unlock locks that are so equipped). So, if I order a new master (black) blank and have a locksmith simply copy the profile of the valet key onto it, will the new master work in the locks for the glovebox and frunk (assuming, of course, that no one ever messed with them and that they're functional).
doug_b_928 |
Feb 19 2017, 08:09 PM
Bump in the hopes that someone with a better understanding of this than me will see it and chime in.
914 RZ-1 |
Feb 19 2017, 09:58 PM
Porsche Padawan Group: Members Posts: 683 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California |
When I got my car I had 3 keys to various combinations of locks! I took all the locks out, and took them to a locksmith. I had him use the ignition key and make ONE key for all the locks. He had the wafers in stock. Cost me about $70.
doug_b_928 |
Feb 20 2017, 06:24 AM
Good to know that might be an option.
slivel |
Feb 20 2017, 11:15 AM
Old car....... older driver Group: Members Posts: 508 Joined: 10-July 04 From: San Diego Member No.: 2,332 Region Association: Southern California |
I recently had an extra key made for my 1975 914 and the locksmith didn't have any blanks for Porsche but found that a blank for older VW is the same.
doug_b_928 |
Feb 20 2017, 11:53 AM
Hmmm...so maybe I can try it out with a blank from a VW before ordering a Porsche blank...
TheCabinetmaker |
Feb 20 2017, 01:17 PM
The cut is the same on both master and valet. Yes, you can cut a new black key from a red one and it will work. At least three posters have already said that.
doug_b_928 |
Feb 20 2017, 01:26 PM
The nuance that was not obvious to me is whether the black master key will work as a master (locking the frunk and glovebox) having been cut from a valet. It seemed like it should but just wanted to be sure. Thanks for confirming.
ChrisFoley |
Feb 20 2017, 02:05 PM
I am Tangerine Racing Group: Members Posts: 7,925 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
My car only came with a valet key. Reading on the classic thread, it seems the only difference is the valet key has an additional slot running the length of the key (that interacts with the 'valet wafer' so that it won't unlock locks that are so equipped). So, if I order a new master (black) blank and have a locksmith simply copy the profile of the valet key onto it, will the new master work in the locks for the glovebox and frunk (assuming, of course, that no one ever messed with them and that they're functional). A good key shop will have suitable blanks (P05). They just won't have the black plastic handle. The difference between master and valet keys is the vertical alignment of upper and lower "wings" of the key. Master key wings are offset to opposite sides and valet key wings are inline. There's a slot in one wafer of the trunk and glove box locks. The slot aligns with the valet key wing, such that the wafer doesn't move when the key is inserted. The wafers are numbered 1 thru 4, easily visible with a small magnifier. The notches on the key can be measured to determine the correct number wafer which corresponds. Deeper notches are higher numbered. When I have new keys made my locksmith doesn't need an existing key, just the 10 wafer sequence and the correct key ID. He has a programmable key machine. |
doug_b_928 |
Feb 20 2017, 02:46 PM
Very nice explanation. Thank you!
Lo-Fi Version | Time is now: 17th May 2024 - 09:14 PM |
