Weber IDF Mixture Screw Question |
tornik550 |
Aug 6 2012, 07:42 PM
Senior Member Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
A few years ago, I obtained a used set of Weber 44 IDF's. The mixture needles are somewhat strange. They are similar to the screws in the picture on the far right. I have always used ones like the far left.
I am having trouble getting my idle mixture correct- which should I use (I currently have the right ones installed cause that is what the carb came with- seems wrong to me)? Attached image(s) |
SUNAB914 |
Aug 7 2012, 06:30 AM
Senior Member Group: Members Posts: 698 Joined: 29-December 08 From: Fredericksburg VA Member No.: 9,880 Region Association: South East States |
The center one is the recent replacement I got on my last order from ACE. I called them to ask because the originals looked like the one on the right also. I was told that they have the longer needle and make them easier to adjust. less travel! That is true, but i will be interested in what you find out here also.
Lo-Fi Version | Time is now: 17th May 2024 - 05:36 PM |
