Window Net |
Window Net |
wndsrfr |
Aug 9 2012, 08:23 PM
Senior Member Group: Members Posts: 1,429 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
Anyone installed a window net? I just stripped out the glass and regulators etc. and am now considering putting on a net. If so, how did you anchor it?
Bullethead |
Aug 9 2012, 09:24 PM
Oil Cooled heart Group: Members Posts: 897 Joined: 24-June 10 From: South Florida Member No.: 11,875 Region Association: South East States |
Depending on the net kit either weld holed tabs (spring rod type) or if using a latch receiver (seatbelt type) those come with the parts needed to weld to the cage.
http://www.speedwaymotors.com/Latch-Style-...nches,3465.html Hope that helps. |
brumi |
Aug 12 2012, 07:20 PM
Newbie Group: Members Posts: 10 Joined: 30-May 12 From: new york Member No.: 14,498 Region Association: North East States |
Anyone installed a window net? I just stripped out the glass and regulators etc. and am now considering putting on a net. If so, how did you anchor it? Anchoring the bottom of the net is the real problem Until IO Port recently came out with a net with adjustable straps on the bottom that can wrap around a NASCAR style door bar ( roll cage door bar ) or any type door bar ( bolt in etc.) It is currently not allowed ( SCCA ) to anchor bottom of net on the door itself. Must be anchored to cage |
Lo-Fi Version | Time is now: 17th May 2024 - 05:36 PM |
