quick wheel question, backspacing...Mueller? |
Trekkor |
Oct 23 2004, 01:46 PM
what is the *correct* backspacing for the four lug that will allow the use of a 205/50/15 without rolling the rear fender lips?
or what are the ones that will work? KT |
Aaron Cox |
Oct 23 2004, 05:20 PM
Trekkor |
Oct 24 2004, 11:30 AM
The chart didn't help. Thanks, anyway. I think it's for *real* Porsches, with five bolts. (IMG:style_emoticons/default/lol2.gif) KT |
Demick |
Oct 24 2004, 12:51 PM
Correct backspace is about 120mm +- 5mm (4 bolt or 5 bolt). But a little more backspace is helpful when trying to fit 7" wheels.
Demick |
Trekkor |
Oct 24 2004, 12:59 PM
So, just a hair over 4.5 inches?
I have access to some aluminum rims that are 4-4.125 inches . They'll rub, huh? KT |
Demick |
Oct 24 2004, 01:48 PM
Actually closer to 4.75"
4.125" is VW bug territory. The infamous Riviera's mostly have a 4" backspace. You won't fit a 205 tire on those without some fender pulling (and then some). Demick |
Aaron Cox |
QUOTE(trekkor @ Oct 24 2004, 11:59 AM) So, just a hair over 4.5 inches? I have access to some aluminum rims that are 4-4.125 inches . They'll rub, huh? KT get a 1/4 inch spacer - DONE |
Demick |
Oct 24 2004, 06:38 PM
QUOTE(acox914 @ Oct 24 2004, 11:48 AM) get a 1/4 inch spacer - DONE Spacers are the equivalent of even less backspace, so it will make the fit even worse. Demick |
Aaron Cox |
Oct 24 2004, 07:12 PM
QUOTE(Demick @ Oct 24 2004, 05:38 PM) QUOTE(acox914 @ Oct 24 2004, 11:48 AM) get a 1/4 inch spacer - DONE Spacers are the equivalent of even less backspace, so it will make the fit even worse. Demick oh, i thought he meant they's rub his inside wheelwell.... |
Lo-Fi Version | Time is now: 18th May 2024 - 02:18 AM |
