442nd914s |
Member ![]() ![]() Group: Members Posts: 139 Joined: 25-July 12 From: KC Suburb Member No.: 14,718 Region Association: None ![]() |
I'm new to this forum and new to these engines, so be easy on me.
So I recently purchased a '73 2.0Lt EFI 914 and desided to replace some of the items. In the process, I discovered that all 4 spark plugs had just a hint of oil on them. Other than being a little oily, they are in great condition. No corrosion, center electrodes like new. What gives? I also removed the intake manifold to discover a slight coat of oilthru out the inside of it. Not baked and not so fresh that I would have enough for an oil change. What I find a little bazzar is that, the car along with the engine, have been in storage for 20 years. (this is the reason why I'm checking and double checking parts before I try to start it) Any thoughts? Thanks for the help. |
JawjaPorsche |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,463 Joined: 23-July 11 From: Clayton, Georgia Member No.: 13,351 Region Association: South East States ![]() |
Watch those fuel lines if they are 20 years old. I would replace them.
toadman |
Member ![]() ![]() Group: Members Posts: 168 Joined: 26-December 05 From: Cincinnati, OH Member No.: 5,316 ![]() |
Is it possible the PO used a fogging oil spray before putting the car in storage?
JamesM |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,100 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region ![]() |
The head vents and the PCV both vent back to the intake on a stock setup.
Lo-Fi Version | Time is now: 12th July 2025 - 07:07 AM |
