GB- CV joint bolts drilled for safety wire, $2.25 each GB Closes Nov 15th |
Mikey914 |
Aug 12 2012, 07:17 PM
The rubber man Group: Members Posts: 12,669 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
These are new, and drilled for safety wire. The beauty is that you don't have to replace all the bolts, so if you want piece of mind that your CV joints will not come off, you can safety wire the bolts on. This will make it much easier.
Who needs em? Attached thumbnail(s) Attached image(s) |
Lo-Fi Version | Time is now: 18th May 2024 - 02:22 PM |
