| brant |
Oct 24 2004, 09:19 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,120 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
This is all for an early 911 motor with and ancient 1967- 2 piece points distributor.
I was intending to run a pertronix ignitor points replacemnt in it, but found out last night that it doesn't fit..... so now I'm re-educating and re-shopping... I run a crane in a different car and see that they do make a model to fit this dinasaur.... but my first question: -Does an inline resistor prior to a coil, ultimately hurt the strength of the spark put out from the coil? next question: I'm running an MSD box and their blaster coil, but want to replace the points... -Does MSD make a points replacement now? anybody know what other racers are using to replace points... specifically other racers with these ancient/small 2.0/6 vintage motors? tia brant |
| Joe Bob |
Oct 24 2004, 09:35 AM
Retired admin, banned a few times ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None |
Check with Summit racing.....Crane optical units that repalce the points will work with most CDI boxes. BTW....you MAY need a tach adapter for the stock P-car tach. I went with an aftermarket tach on Frank and it workied withOUT the adapater.
| Cap'n Krusty |
Oct 24 2004, 10:46 AM
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California |
I run a Crane Allison XR 700on my '65 911, and like it alot. I don't use a conventional Pcar CDI, just the Crane box, and have no more plug fouling problems ... Price is right. The Cap'n
| ein 6er |
Oct 24 2004, 11:27 AM
Senior Member ![]() ![]() ![]() Group: Benefactors Posts: 1,115 Joined: 11-February 03 Member No.: 300 Region Association: None |
brant,
i'm been running the crane xr 700 on the '67 2.0 in my 914 for about 2 years now with no problems with it. i'm useing the stock cdi to trigger the crane box and i didn't need a tach adapter. if you use the right shutter wheel, you don't need to remove the points mounting post .......... like i did. (IMG:style_emoticons/default/headbang.gif) |
| brant |
Oct 25 2004, 09:02 AM
thanks fellas...
I'm fairly ignorant, but in theory what do you guys know about the thought I had regarding the resistor..(yes really a different question) looks like I'll probably go with the crane agian then. brant |
| SLITS |
Oct 25 2004, 09:20 AM
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
Ran the Crane Allison on the race cars without a resistor and came up with two problems:
1. The spark was so "hot" it disintegerated the cap center electrode, but the spark would still jump from the cap to the rotor (IMG:style_emoticons/default/biggrin.gif) 2. The spark was so brilliant, it would trigger the LED (IMG:style_emoticons/default/smoke.gif) or was it the spark jumping around inside causing the misfire? Yea, I put the resistor in line to drop the voltage to the coil to 9V. No problems after that and no fouled plugs. |
| brant |
Oct 25 2004, 09:26 AM
ohh...
good input, I hadn't even considered the too much power idea.. brant |
Lo-Fi Version | Time is now: 15th January 2026 - 11:52 AM |
