Alternator upping amperage suggestions, I already up'd to 75 amps... not enough. |
pnewman |
Aug 18 2012, 10:08 PM
Member Group: Members Posts: 371 Joined: 15-February 05 From: Lincolnshire, IL Member No.: 3,606 Region Association: Upper MidWest |
Ok Ok Ok.
I have to many gadgets in my car for a 75 amp alternator to support. They all work great but they are pigs: Heated seats high power stereo Sub woofer w/ amp HID headlights windshield washer pump Interior / map lights in rear view mirror etc. So I have a seperate circuit and an electrical sub-panel to support the load safely but simply put: "I need more power Scotty!" Took my old 50 amp Bosch to an alternator / starter rebuilder and after looking at it a bit they recommended the AC Delco 100 / 105+ amp single wire alternator with integral regulator for $110 rebuilt. He stated that it could run the dash idiot light too. Not quite ready to bypass the voltage regulator etc. I am sure this mod is probably old hat for some. Thoughts? Thanks in advance, (IMG:style_emoticons/default/driving-girl.gif) Pete |
GeorgeRud |
Aug 19 2012, 06:51 AM
It really should just come down to whether the Delco unit would fit in the available space and the wiring harness can be modified. Haven't really heard much in people replacing their alternators with higher power ones. Have you added up the amperage required by your items? Do they add up to over 50amps?
You might want to check with Sol Snyderman at Perfect Power in Buffalo Grove to see if he's ever heard of such a swap. Brad Mayeur at 914Ltd in E. Peoria would be another great source of information if no one hare has any experience with the larger alternator. |
ArtechnikA |
Aug 19 2012, 07:35 AM
HID headlights HID's actually consume less current than halogens. Why do you think they're in Priius's? About 35W a side. As George mentioned, space is the big factor unless you're you're going to use bracketry like an AC compressor. The other big factor is cooling, which is already a little marginal for a high-amp alternator in the stock location. "Standard" alternators (front-engine application) tend to live out in the free air and can dissipate their heat load. Getting cool air to and hot air from a 914 alternator is a challenge. |
Mike Bellis |
Aug 19 2012, 09:30 AM
I think you should go with the GM alternator. I run a GM style Powermaster 180 Amp unit. There is no advantage to keeping the stock VR unless you intend to concourse the car.
Biggest upgrade for the buck is up sizing all wires. I run a #2 charge wire and have upgraded all grounds. I bet your stereo wiring is bigger than most of the stock 914 wiring. Add extra grounds, bigger wire. Add a ground from the alternator to the battery. If your amplifier has a 20 amp fuse, that means it can take spikes of current up to 20 amps. The factory alternator charge wire is a #8. This is barely adequate for 20 amps of DC current. The car battery acts like a buffer, not allowing all that current into the battery at one time to recharge. This is mostly due to internal resistance. Your amplifier need instant current flow. Here is the advantage of a charging capcitor. The cap will charge and discharge instantly to help out. Most people do not realize that DC current takes a bigger conductor than AC current. Because of this, most will quote AC amperage charts. The world realized this and chose Tesla's AC power over Edison's DC power. Edison needed a 4" diameter conductor to push DC down a single block of homes. Tesla only needed a 1/4" conductor for the same distance with AC power. When I was manager at a car stereo shop (and master installer), we would use #8 amplifier wires at a minimum. We also upgraded the ground from battery to chassis and battery to engine block. This worked well for night time headlight dimming problems. The wiring and chassis on your 914 is old, rusty and corroded after 40 years. The wiring has reached its life span. The unit body is now grounded through rusty metal and spot welds. Start with upgrading your wiring first. |
jsayre914 |
Aug 19 2012, 01:43 PM
Speed Up !!! Group: Members Posts: 3,188 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region |
I think you should go with the GM alternator. I run a GM style Powermaster 180 Amp unit. Can we see some pics of that alternator installed? (IMG:style_emoticons/default/happy11.gif) As far as an easy swap, the 75 amp alternator from a VW bus fits right in, I have pics in my Blog with side by side pictures. That gives you an instant 25 amps, or bring it to your alternator guy, I had the 75 amp rewound to 120amp Hasnt blown anything up yet (IMG:style_emoticons/default/first.gif) |
pnewman |
Aug 21 2012, 10:49 PM
I think you should go with the GM alternator. I run a GM style Powermaster 180 Amp unit. Can we see some pics of that alternator installed? (IMG:style_emoticons/default/happy11.gif) As far as an easy swap, the 75 amp alternator from a VW bus fits right in, I have pics in my Blog with side by side pictures. That gives you an instant 25 amps, or bring it to your alternator guy, I had the 75 amp rewound to 120amp Hasnt blown anything up yet (IMG:style_emoticons/default/first.gif) I like the idea of having a modified or rewound unit that is a direct fit. Have you had any cooling issues with the 125 amp? Where / who did it? How much did it cost? I have gone over the rust throughout my whole car and she is solid plus(longs in and out as well as rear suspension and hell hole etc. I like the idea of adding and updating grounds. I already upgraded the ground from the battery to the body. I like the idea of adding a ground between the battery and the engine block. I think that will be my next move. A capacitor should be a good idea to even things out while I am at it. |
pnewman |
Aug 21 2012, 10:51 PM
I am concerned about the cleanlyness and reliability of bypassing the VR and am not a fan of splicing into the wiring harness to accomplish the mod. Although I might not have to at all sans the idiot light accomodation.
pnewman |
Aug 21 2012, 10:52 PM
I think you should go with the GM alternator. I run a GM style Powermaster 180 Amp unit. PLEASE SHOW US SOME PICS OF HOW YOU FIT AND SET IT UP. (IMG:style_emoticons/default/piratenanner.gif) |
Rod |
Aug 22 2012, 10:31 AM
Senior Member Group: Members Posts: 616 Joined: 1-January 08 From: Farnham UK Member No.: 8,526 Region Association: England |
Interested in this too.
A friend of mine has just fitted a Mazda Alternator to a Notchback, but not had the engine running as yet (IMG:style_emoticons/default/wink.gif) I'll ask him for some images too.. |
balljoint |
Aug 22 2012, 01:32 PM
davep was building higher output alternators. Try sending him a PM.
jsayre914 |
Aug 22 2012, 02:06 PM
I like the idea of having a modified or rewound unit that is a direct fit. Have you had any cooling issues with the 125 amp? Where / who did it? How much did it cost? No cooling issues, works just like the original. Purchased the unit from a vendor on Evilbay, the guy that was selling it had a bunch of brand new units. forgot the guy (IMG:style_emoticons/default/smoke.gif) no idea what i paid (IMG:style_emoticons/default/smoke.gif) (IMG:style_emoticons/default/smoke.gif) Im sure there are units out there. |
dlestep |
Aug 22 2012, 02:12 PM
I am smilin'... Group: Members Posts: 890 Joined: 15-January 08 From: Sunrise Florida Member No.: 8,573 Region Association: South East States |
ArtechnikA |
Aug 22 2012, 02:14 PM
QUOTE No cooling issues, works just like the original. Purchased the unit from a vendor on Evilbay Which leads us to the inevitable question - how do you know it's actually producing (or capable of producing) 125A? And the next question - are all the wires between the alternator output and the battery rated for 125A at 12V ? 1500W is serious energy - like 2X a typical 911 alternator - and they have way better cooling - are lots larger. Color me skeptical... I'm glad it's working for you, but I am highly dubious it's actually capable of producing anything like 125A. |
ArtechnikA |
Aug 22 2012, 02:16 PM
The world realized this and chose Tesla's AC power over Edison's DC power. Not to be nerdy, but don't you have that backwards. In the words of Al 'White and Nerdy' Yankovich - No. Tesla and Westinghouse put AC on the map. Edison championed DC and - well - he's famous for other stuff... |
Matt Meyer |
Aug 22 2012, 02:28 PM
Überlurker Group: Members Posts: 216 Joined: 2-December 03 From: Eastern Washington Member No.: 1,411 Region Association: Pacific Northwest |
I don't see why you would ever run a one wire setup.
This is for a different vehicle but here is a link to a discussion on one vs. three wire connection and converting from a externally regulated alternator to an internally regulated alternator. Bob Skelly's Alternator Site The CS series alternators and the 12SI series are supposed to have excellent cooling. What would you use for a pulley? I think these typically spin at about 1/2 engine speed. The pulley on the fan is pretty big which means you should have a big pulley on the alternator. The pulleys on modern alternators are pretty small. Maybe they are suppposed to spin faster. |
damesandhotrods |
Aug 22 2012, 02:34 PM
Senior Member Group: Members Posts: 568 Joined: 26-September 10 From: Santa Cruz California Member No.: 12,218 Region Association: Northern California |
[quote name='pnewman' date='Aug 18 2012, 09:08 PM' post='1725729']
Ok Ok Ok. I have to many gadgets in my car for a 75 amp alternator to support. They all work great but they are pigs: If “They all work great” why are you worrying about the size of your alternator? |
jsayre914 |
Aug 22 2012, 02:53 PM
Which leads us to the inevitable question - how do you know it's actually producing (or capable of producing) 125A? And the next question - are all the wires between the alternator output and the battery rated for 125A at 12V ? The stereo bumps, i mean it really really pushes in on your chest (IMG:style_emoticons/default/biggrin.gif) And the wiring was all upgraded. Everything is brand new, from the custom Jeff Bowlsby harness with 2 runs of 8g wire, then the o gauge power and ground. then I added ground wires from the alternator bolt to multiple ground points in the engine bay. Yes the wiring can handle it. None of my added electronics are using stock leads. I run power and ground from the battery all the way up to the Desmazes Delayeator. (IMG:style_emoticons/default/aktion035.gif) |
Bartlett 914 |
Aug 22 2012, 03:07 PM
Advanced Member Group: Members Posts: 2,215 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
[quote name='damesandhotrods' date='Aug 22 2012, 03:34 PM' post='1727607']
[quote name='pnewman' date='Aug 18 2012, 09:08 PM' post='1725729'] Ok Ok Ok. I have to many gadgets in my car for a 75 amp alternator to support. They all work great but they are pigs: If “They all work great” why are you worrying about the size of your alternator? [/quote] I would answer that they may work but if they are working near the maximum output, you may find yourself dead on the road. I would prefer to have a buffer zone. |
damesandhotrods |
Aug 22 2012, 07:20 PM
Then why not install an amp meter and monitor your current draw? I don’t mean to get all Myth Busters on you, but if you don’t know, you’ll never feel confident in the car.
This also gets into your switches. If your devices are wired through the switches and they can’t handle the current you’re looking at a potential fire. If you’re drawing so much current the switches should be controlling relays and the relays handling the current. |
dlestep |
Aug 22 2012, 07:24 PM
The world realized this and chose Tesla's AC power over Edison's DC power. Not to be nerdy, but don't you have that backwards. In the words of Al 'White and Nerdy' Yankovich - No. Tesla and Westinghouse put AC on the map. Edison championed DC and - well - he's famous for other stuff... You are most certainly correct ! I had it backwards...ha ! |
Lo-Fi Version | Time is now: 8th May 2024 - 08:11 PM |
