Breaker bar or an inexpensive 12v Impact Wrench?, Answer surprised me.... |
sfrenck |
Aug 20 2012, 07:27 PM
Member Group: Members Posts: 492 Joined: 28-February 10 From: Wilmington, DE Member No.: 11,411 Region Association: MidAtlantic Region |
Well, couldn't break siz lug
I couldn't believe that I actually spun the blocked front tire instead breaking the lug Then I saw this online.... A Kawasaki 12v Impact Wrench from Pepboys. That's right - it runs off the cigarette lighter. No way did I think this would work - but for $50 and no way to get my non-running car out of the garage to a mechanic with air tools I figured I'd give it a try. Heck, it's rated for 280 ft-lbs of torque (IMG:style_emoticons/default/huh.gif) Much to my surprise, after about 10 seconds per rusted lug Initial plan was to spin the |
McMark |
Aug 20 2012, 07:36 PM
I've found that slow, steady increase of torque is WAY less effective than bursts of torque. When I'm loosening tough fasteners by hand I often do this. For example, old brake lines often want to round off when they're stuck and you try slowly increasing the pressure. But I have great success with breaking these nuts loose by pushing hard repeatedly, on-off-repeat.
But success with a 12v cigarette lighter tool is really interesting. Might have to add one of those to my collection. (IMG:style_emoticons/default/smilie_pokal.gif) |
maf914 |
Aug 23 2012, 11:40 AM
(IMG:style_emoticons/default/hijacked.gif)
Interesting thread concerning the 12 volt impact drill. I have been looking at 120 volt versions at Lowe's and Home Depot, wondering if they are worth the investment. I don't have a big compressor in my garage, so air tools are out. I get irritated when rechargable batteries die, so I didn't want to go rechargable. Does anyone have experience with 120 volt impact drills? Are they worthy? (IMG:style_emoticons/default/idea.gif) Thanks. Sorry for the hijack. |
balljoint |
Aug 23 2012, 12:25 PM
I have two electric impact wrenches, a little one and a big one. They have come in handy many times.
patssle |
Aug 23 2012, 12:39 PM
Senior Member Group: Members Posts: 981 Joined: 28-August 09 From: Houston, TX Member No.: 10,741 Region Association: None |
I had to pull off the rear axles a month ago...that axle nut. A breaker bar with 225 lbs at the end didn't do it. Soaked in PBlaseter didn't do it. Bought a 500+ ft-lbs air impact wrench - that didn't do it either.
But it must of loosened it up because a 225 lbs human jumping up and down on the breaker bar finally did it. We were literally ready to quit when it came loose. The breaker bar bent before that nut came off. |
Aug 23 2012, 12:43 PM
I had stopped by after you tried the breaker bar and loosened up the nuts. Actually it was my daughter that broke them free. Didn't want to hurt your feelings.
MartyYeoman |
Aug 23 2012, 12:50 PM
Senior Member Group: Members Posts: 1,518 Joined: 19-June 03 From: San Ramon, CA Member No.: 839 Region Association: Northern California |
I've got a 3/4" breaker bar stuck into a 48" long piece of black iron pipe.
It puts the load out at about 60" from the socket. Never had a problem breaking anything loose, not even axial bolts (bus, bug or 914). Just need to stand on it and bounce. (IMG:style_emoticons/default/biggrin.gif) |
balljoint |
Aug 23 2012, 12:54 PM
I had stopped by after you tried the breaker bar and loosened up the nuts. Actually it was my daughter that broke them free. Didn't want to hurt your feelings. (IMG:style_emoticons/default/pinch.gif) (IMG:style_emoticons/default/laugh.gif) |
zymurgist |
Aug 23 2012, 12:55 PM
"Ace" Mechanic Group: Members Posts: 7,411 Joined: 9-June 05 From: Hagerstown, MD Member No.: 4,238 Region Association: None |
Cool tip. And it's Ninja Green too! (IMG:style_emoticons/default/ninja.gif)
ThePaintedMan |
Aug 23 2012, 01:03 PM
I've found that slow, steady increase of torque is WAY less effective than bursts of torque. When I'm loosening tough fasteners by hand I often do this. For example, old brake lines often want to round off when they're stuck and you try slowly increasing the pressure. But I have great success with breaking these nuts loose by pushing hard repeatedly, on-off-repeat. But success with a 12v cigarette lighter tool is really interesting. Might have to add one of those to my collection. (IMG:style_emoticons/default/smilie_pokal.gif) Force = mass x acceleration (IMG:style_emoticons/default/biggrin.gif) Acceleration can really make a difference sometimes. |
Eric_Shea |
Aug 23 2012, 02:09 PM
QUOTE Force = mass x acceleration 2 (squared) |
Aug 23 2012, 02:13 PM
I've got a 3/4" breaker bar stuck into a 48" long piece of black iron pipe. It puts the load out at about 60" from the socket. Never had a problem breaking anything loose, not even axial bolts (bus, bug or 914). Just need to stand on it and bounce. (IMG:style_emoticons/default/biggrin.gif) I have broken both a 1/2 inch and a 3/4 inch breaker bar doing the rear nuts with a pipe while bouncing. Twisted the end off both tools (craftsman thank you for the replacement) Never had any issues using an impact gun, I have quite a few. 12VDC impact...that is now on my list... Battery operated ones do tires really fast. rich |
Valy |
Aug 23 2012, 02:16 PM
Senior Member Group: Members Posts: 1,675 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
QUOTE Force = mass x acceleration 2 (squared)Eric, Seems you've been picking in Jake's notes on how to calculate engine power. (IMG:style_emoticons/default/laugh.gif) |
Brodie |
Aug 23 2012, 03:43 PM
Newbie Group: Members Posts: 39 Joined: 28-October 09 From: Kansas Member No.: 10,990 Region Association: None |
The unfortunate part about removing stuck lug nuts with an impact is quite often you will twist the studs off. I wish I had a better solution for you, but you'll have to do what you have to do to get them off. Try reversing and than going forward in really short bursts using a medium torque setting. If you break them off than you'll have to put in a couple of new studs. If you don't want to buy an impact yourself ask a local repair shop to do it for you. If it was my shop I'd buzz them off for free.
Mike Bellis |
Aug 23 2012, 04:04 PM
Electric motors start turning at max torque. I have both air and electric guns. My electric gun is way better at loosening bolts, my air gun is better at tightening bolts.
stugray |
Aug 23 2012, 06:08 PM
"Does anyone have experience with 120 volt impact drills? Are they worthy? idea.gif"
I have had a 120V impact wrench for at least 20 years and have beat the crap out of it (commercial use, not just hobby). It will still break off pretty much any bolt you throw at it. I dont recall the brand but I will check. Stu |
okieflyr |
Aug 23 2012, 06:18 PM
9fauxteen Group: Members Posts: 816 Joined: 9-January 05 From: Phila PA Member No.: 3,426 Region Association: North East States |
Scott,
If you get in a jam again give me a hollar. I've got tools and stuff down the street from ya. |
Elliot Cannon |
Aug 23 2012, 09:49 PM
The key for me has always been "impact". As in "impact wrench". If you use a breaker bar with a cheater pipe, put a bunch of weight on the cheater pipe and then put some "IMPACT" (BFH) right where the pipe slides onto the breaker bar.
76-914 |
Aug 24 2012, 08:55 AM
I've found that slow, steady increase of torque is WAY less effective than bursts of torque. When I'm loosening tough fasteners by hand I often do this. For example, old brake lines often want to round off when they're stuck and you try slowly increasing the pressure. But I have great success with breaking these nuts loose by pushing hard repeatedly, on-off-repeat. But success with a 12v cigarette lighter tool is really interesting. Might have to add one of those to my collection. (IMG:style_emoticons/default/smilie_pokal.gif) Force = mass x acceleration (IMG:style_emoticons/default/biggrin.gif) Acceleration can really make a difference sometimes. (IMG:style_emoticons/default/agree.gif) The key for me has always been "impact". As in "impact wrench". If you use a breaker bar with a cheater pipe, put a bunch of weight on the cheater pipe and then put some "IMPACT" (BFH) right where the pipe slides onto the breaker bar. This might be the first time that I agree with (IMG:style_emoticons/default/poke.gif) Elyut but, (IMG:style_emoticons/default/agree.gif) Also, this method is less destructive. |
Lennies914 |
Aug 24 2012, 08:48 PM
Slacker Group: Members Posts: 828 Joined: 9-January 10 From: NorCal Member No.: 11,216 Region Association: Northern California |
I use one of these every day. Love it! I also have a 120v. one, for when the cordless isn't enough. |
Lo-Fi Version | Time is now: 15th May 2024 - 11:59 PM |
