Doug's A/C System, R&D/Build Thread |
dlee6204 |
Aug 22 2012, 08:05 PM
Howdy Group: Members Posts: 2,162 Joined: 30-April 06 From: Burnsville, NC Member No.: 5,956 |
I thought I would document my A/C adventure in the hopes that it would be a good reference for anyone else considering A/C. I’ll first touch base on the stock system and on custom options and then start building my own system to start testing on. I’ve working on a few systems before but I'm sure there is someone that knows more than me so don't be shy sharing or adding anything. (IMG:style_emoticons/default/smile.gif)
To begin things off here is one of the better overviews of an A/C system. Follow the link and you can see a breakdown of the whole system. http://www.movacs.com/How%20it%20works/index.html Anytime I refer to the stock system I will be referring to the dealer installed VPC system mostly because the only A/C cars I had came with this system and I have plenty of parts around. I also borrowed some photos off this site so if I used any of yours... Thanks. (IMG:style_emoticons/default/smile.gif) Compressor: The compressor that came on dealer installed A/C systems was a York Piston style compressor that had a capacity of 6 cubic inches/Rev. From what I could find it used about 7-10 horsepower from the engine. You can still use this compressor however there are better, more efficient options out there. When choosing a new compressor it is a good idea to find one with a similar capacity. In this case going bigger does not mean better. An A/C system works as a whole unit and if you dramatically change one aspect of it, you will likely see negatives effects elsewhere. Choosing a compressor that’s too big will overwork the system, yielding no little to no benefit, and create a not-as-efficient system. During my search I looked mostly at Sanden style compressors so that's what I'll be referring to in my build. Using a modern compressor like the Sanden will only use about 3-4 hp from the engine. I have heard quite a few people use the Sanden 508 compressor with good results. It has an approximate displacement of 8 cubic inches/rev, which IMO is slightly more than I'd like to make a jump to. I'm not saying it wouldn't work, it obviously works, however I think I will get slightly better results and pressures using the Sanden 507 (approx. 7 cubic inches/rev). The SD507 is also slightly smaller in size than the 508. Here is a picture of the York Compressor A side by side with the SD507 And here is a SD508 |
dlee6204 |
Jun 1 2013, 02:35 PM
Now for some boring stuff...
I thought I would give an update on some of my results. The other day I did and initial charge on the system and had the following results: Ambient Temp: 75 Fahrenheit Low Pressure: 40 psi High Pressure:250 psi Evaporator (Air Vent) Temp: 58 Fahrenheit Here is one reference I use for the range of temperatures/pressures... http://www.ackits.com/aacf/ptchart.cfm From the initial test my numbers were a little high. From experience I knew the likely culprit was inadequate airflow over the condenser. Last year the squirrel cage fan in the condenser box froze up so I replaced it with a small electric radiator fan and I wasn't too happy with the way I mounted it and obviously that method didn't work too well so I reconfigured it today. Sorry, no pictures (IMG:style_emoticons/default/sad.gif) I mounted the fan on the underside of the condenser so that it pulls air. Worked great. My new readings are: Ambient Temp: 82 Fahrenheit Low Pressure: 33 psi High Pressure:230 psi Evaporator (Air Vent) Temp : 54 Fahrenheit That's a temperature drop of 28 degrees! Not too bad. Now I need to go test drive it and see how low it goes. (IMG:style_emoticons/default/driving.gif) |
Lo-Fi Version | Time is now: 4th May 2024 - 11:11 PM |
