Doug's A/C System, R&D/Build Thread |
dlee6204 |
Aug 22 2012, 08:05 PM
Howdy Group: Members Posts: 2,162 Joined: 30-April 06 From: Burnsville, NC Member No.: 5,956 |
I thought I would document my A/C adventure in the hopes that it would be a good reference for anyone else considering A/C. I’ll first touch base on the stock system and on custom options and then start building my own system to start testing on. I’ve working on a few systems before but I'm sure there is someone that knows more than me so don't be shy sharing or adding anything. (IMG:style_emoticons/default/smile.gif)
To begin things off here is one of the better overviews of an A/C system. Follow the link and you can see a breakdown of the whole system. http://www.movacs.com/How%20it%20works/index.html Anytime I refer to the stock system I will be referring to the dealer installed VPC system mostly because the only A/C cars I had came with this system and I have plenty of parts around. I also borrowed some photos off this site so if I used any of yours... Thanks. (IMG:style_emoticons/default/smile.gif) Compressor: The compressor that came on dealer installed A/C systems was a York Piston style compressor that had a capacity of 6 cubic inches/Rev. From what I could find it used about 7-10 horsepower from the engine. You can still use this compressor however there are better, more efficient options out there. When choosing a new compressor it is a good idea to find one with a similar capacity. In this case going bigger does not mean better. An A/C system works as a whole unit and if you dramatically change one aspect of it, you will likely see negatives effects elsewhere. Choosing a compressor that’s too big will overwork the system, yielding no little to no benefit, and create a not-as-efficient system. During my search I looked mostly at Sanden style compressors so that's what I'll be referring to in my build. Using a modern compressor like the Sanden will only use about 3-4 hp from the engine. I have heard quite a few people use the Sanden 508 compressor with good results. It has an approximate displacement of 8 cubic inches/rev, which IMO is slightly more than I'd like to make a jump to. I'm not saying it wouldn't work, it obviously works, however I think I will get slightly better results and pressures using the Sanden 507 (approx. 7 cubic inches/rev). The SD507 is also slightly smaller in size than the 508. Here is a picture of the York Compressor A side by side with the SD507 And here is a SD508 |
friethmiller |
Apr 29 2021, 02:48 PM
Member Group: Members Posts: 468 Joined: 10-February 19 From: Austin, TX Member No.: 22,863 Region Association: Southwest Region |
Condenser Install I think I mistakenly placed my previous photos on Doug's other commercial A/C thread. Go there to see my pre-fit photos. So, here we go! Here are my final install pics of my A/C Condenser unit on my '74. I had to make a last minute adjustment to the flipped down portion of the mounting cover (photos 2 and 3). My issue was that it just stuck down too low. If I hit a speed bump or something, the entire condenser would be ripped out of my trunk. I also wanted something to cover up the front portion of the grate. I satisfied both issues by pounding the metal bracket flat and then cutting out an inner rectangle - leaving enough to bend down a much smaller scoop.
Attached thumbnail(s) Attached image(s) |
Chris914n6 |
Apr 30 2021, 03:35 PM
Jackstands are my life. Group: Members Posts: 3,310 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
Condenser Install I think I mistakenly placed my previous photos on Doug's other commercial A/C thread. Go there to see my pre-fit photos. So, here we go! Here are my final install pics of my A/C Condenser unit on my '74. I had to make a last minute adjustment to the flipped down portion of the mounting cover (photos 2 and 3). My issue was that it just stuck down too low. If I hit a speed bump or something, the entire condenser would be ripped out of my trunk. I also wanted something to cover up the front portion of the grate. I satisfied both issues by pounding the metal bracket flat and then cutting out an inner rectangle - leaving enough to bend down a much smaller scoop. I assume you're using a pusher fan. Bend the flap straight down and use it as a lip to attach a flexible rubber/plastic dam (something cheap from HD that can be replaced as needed). That little 1" or so isn't going to do anything but 3-4" will. You need to create high pressure in front and low behind to get good circulation thru. Looks great. |
Lo-Fi Version | Time is now: 4th May 2024 - 05:50 PM |
