Does this gauge fit the stock sender |
jsayre914 |
Aug 26 2012, 03:42 PM
Speed Up !!! Group: Members Posts: 3,188 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region |
It dosent say that it comes with the sender?
(IMG:style_emoticons/default/confused24.gif) Will this work on a stock 1973 2.0 in place of the original gauge. Same wires? Could it be plug and play? LINK Attached image(s) |
Black22 |
Aug 26 2012, 03:54 PM
Senior Member Group: Members Posts: 886 Joined: 1-November 07 From: Creswell, OR Member No.: 8,290 Region Association: Pacific Northwest |
I'm not sure what is considered a stock sensor, but I do know that there are different valued senders out there. A 200C sender will read differently than a 150C sender.
Google a sender that is for use with that particular gauge. Go to eGauges.com Pick that VDO gauge and it will have a link to all the senders that work with it. For the Taco plate it looks like p/n 323-055. Which is a 150C/300F value sender. The taco plate is a 14mm thread IIRC. Verify first though. |
Aug 26 2012, 09:02 PM
It should work, as in "give you a reading".
It will probably read wrong, though. Depends on the resistance range that the gauge expects and the resistance that your sender gives you. They might match, but there's a good chance they won't. --DD |
gothspeed |
Aug 27 2012, 02:55 PM
Senior Member Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None |
When I bought one of those VDO oil temp gauges and its matching sender ........ the sender that was already in the taco plate ..... was exactly the same part # as the one I bought ........ so I swapped them just in case the old one was tired.
Lo-Fi Version | Time is now: 16th May 2024 - 01:28 AM |
