| moggy |
Sep 2 2012, 02:20 PM
Member ![]() ![]() Group: Members Posts: 192 Joined: 15-December 04 From: Wales Member No.: 3,285 |
My steering wheel has been developing a wobble over the past few years, now it's time to do something about it. I've ruled out the steering wheel itself. The steering wheel wobbles up and down. as if it's loose I've heard there's a bearing that's a common item that causes this, but looking at the Pelican Parts site its not clear to me which one.
http://www.pelicanparts.com/catalog/shopca...r_pg2.htm#item9 The above link shows the following parts: Upper steering column bushing repair sleeve Inner steering shaft bearing Upper steering shaft bearing Lower shaft bearing Steering column split ring bushing Pressure spring in sttering shaft Initially I went in to buy a steering bearing now I'm totally confused (IMG:style_emoticons/default/confused24.gif) what do I need to buy? |
moggy Wobbly steering wheel Sep 2 2012, 02:20 PM
scotty b before you buy anything make certain all of your n... Sep 2 2012, 02:47 PM
moggy
before you buy anything make certain all of your ... Sep 2 2012, 03:41 PM
Brian_Boss Repair bushing replaces the plastic center of the ... Sep 2 2012, 04:07 PM
914_teener
Repair bushing replaces the plastic center of the... Sep 2 2012, 05:02 PM
moggy Thanks guys :DRUNK:
I will check that is the is... Sep 3 2012, 12:53 PM
chuckc
My steering wheel has been developing a wobble ov... Sep 7 2012, 06:55 AM
rwilner I used this bushing to repair this exact issue on ... Sep 7 2012, 11:36 AM![]() ![]() |
Lo-Fi Version | Time is now: 4th March 2026 - 11:12 PM |
