> Maximum rear wheel backspacing?
Eddie914
post Oct 26 2004, 12:42 PM
Unregistered
At what backspacing do the rear tires/wheels contact the rear inner fenders?
Assume:
-2 degrees camber.
245/45/16 tire
16 x 9 wheel
Thanks
Eddie
Brett W
post Oct 26 2004, 12:47 PM
My 15x8 with a 9.5 in slick would hit with a backspace of 5 inches. Ran about the same settings as far as suspension goes. Put a .250 spacer and problem solved.
Mueller
post Oct 26 2004, 02:25 PM
914 Freak!
a 16*8 rim with a 55mm offset and with 225 width tire hit both the trailing arm and the trunk wall....backspacing wise, if you included the thickness of the rim lip, you'd have a rim with about a 6.5" backspace which is too much.
- Lo-Fi Version Time is now: 7th November 2026 - 01:44 PM
