FS - New Pelican Protector shipping case |
GaroldShaffer |
Sep 8 2012, 09:59 AM
FS - I bought this case for shipping my testing tools in when I traveled for work. It is a Pelican Protector Shipping case. It has a custom made insert that can be removed to make more room.
These are commerical grade shipping cases. You can check this link Pelican 1560 Case to see that they retail for over $200 new. I am asking $125 shipped FedEx Ground to your door. I used this case a total of three times in two years (didn't travel like I was planning) so it is in almost new condition. The case specs: Interior (l/w/d cm) 20.37"51.7 x 15.43"39.2 x 9"22.9 Exterior (l/w/d cm) 22.06"56 x 17.93"45.5 x 10.43"26.5 Dimensions Buoyancy Max 104 lbs47.17 kg Range Temp -10 / 210 °F-23 / 99 °C Lid / Case Depth 2"5.1 cm / 7"17.8 cm Weight 20 lbs9.07 kg (with foam) 17 lbs7.71 kg (w/o foam) Special Features Wheels (2) Extendable Handle |
Lo-Fi Version | Time is now: 17th May 2024 - 03:16 PM |
