915 tranny, cv's, 5 lug conversion |
sj914 |
Oct 26 2004, 10:59 PM
I've got stubs and hubs from a 69 911 and a 915 tranny from a an 85. When I went to measure up the axle flanges from the 915 it matches the diameter of the stubs from the 69. Only thing is, is the 69 stubs mount the cv's with 4 bolts and 2 pins. What I was thinking is to have the 2 roll pin holes welded up and then drilled and tapped with the same size bolt hole as the other 4 bolts.
btw the 915 axle flanges and the stubs both use 10mm bolts. Has anyone done this type of modification and on a safety stand point is this something that would be avoided. |
Lo-Fi Version | Time is now: 18th May 2024 - 10:39 AM |
