Running Fiberglass |
Alphaogre |
Sep 12 2012, 12:50 PM
Member Group: Members Posts: 460 Joined: 28-May 12 From: San Diego Member No.: 14,487 Region Association: Southern California |
Just looking to weigh the pros and cons of running Fiberglass bumpers and possibly hood and rear deck lid. How well do they fit? how much weight would you save etc...
Coming from desert racing im not scared of fiberglass or working with it, im Just trying to see if it would be worth investing in it. In the desert you are running in to stuff all the time so the fiberglass makes cheaper to replace panels. My rear deck lid is perfectly fine, though my hood could use some TLC, my bumpers are in decent condition but the rubber strips on them have seen better days. I would rather replace these if they also add an advantage to the weight or deal with them and save the money. I do like the front bumpers with the skirt/ "splitter" incorporated in to them.... Any recommendations on 914 fiberglass distribution? Thanks in advance. |
ConeDodger |
Sep 12 2012, 01:32 PM
Apex killer! Group: Members Posts: 23,574 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Some of the best fiberglass parts I have seen have come from GT Racing and they have had to be reworked some. I am not sure but I have seen the front and rear lids on cars and there is no way to rework them really. They seem to fit just fine.
Bumpers? Not sure here... I plan to use them though... (IMG:style_emoticons/default/biggrin.gif) |
Woody |
Sep 12 2012, 02:30 PM
Sandbox Rabblerouser and head toilet scrubber Group: Members Posts: 3,858 Joined: 28-December 10 From: San Antonio Texas Member No.: 12,530 Region Association: Southwest Region |
I bought my bumpers from Rennspeed. The front fitment could be better as the sides of the bumper don't match up with the car perfectly. The rear on the other hand fits fairly decent. They are very light, I think about 4 pounds each and they come with the mounting brackets molded in. I replaced the rubber impact bumpers as my car is a 75. The old bumpers were 40 pounds each and the shocks were 5 pounds each so the car lost almost 100 pounds. I like the way they look.
http://rennspd.com/P_Detail.asp?PID=311&Task=STD http://rennspd.com/P_Detail.asp?PID=318&Task=STD |
brant |
Sep 12 2012, 06:02 PM
914 Wizard Group: Members Posts: 11,618 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
most of the time the fit is crap...
you will cut weight and you will give up crash protection/safety and you will spend 2x as much $ at the paint shop when your guy tries to get them to fit. replacement metal is cheaper than glass too.... so you really have to want to cut weight to bother with glass. When I built my race only car we set the limit at $50 per a pound. I would replace something on the car with something lighter if I could do it legally for $50/lb. If it was over that I didn't |
Randal |
Sep 12 2012, 08:41 PM
The Getty Design stuff is perfect. I have CF, but assume the FG is the same quality. Fit and finish perfect. |
campbellcj |
Sep 13 2012, 11:11 PM
I can't Re Member Group: Members Posts: 4,542 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
I have GT bumpers, Getty lids and a Rennspeed top. All needed a bit of work. The weight saving is substantial - and it is relatively high-up on the car too.
Woody |
Sep 14 2012, 05:33 AM
I have GT bumpers, Getty lids and a Rennspeed top. All needed a bit of work. The weight saving is substantial - and it is relatively high-up on the car too. How does the Rennspeed top work? The website says it must be pinned in place. Are there provisions for weather seals? |
campbellcj |
Sep 14 2012, 08:14 AM
How does the Rennspeed top work? The website says it must be pinned in place. Are there provisions for weather seals? It is a 'skin' top for racing purposes, no provision for seals or stock-type latches. Mine is attached with dzus fasteners. I've heard that Roger Sheridan might make them as well and of better quality/lighter weight. |
Britain Smith |
Sep 14 2012, 11:44 AM
Nano Member Group: Members Posts: 2,354 Joined: 27-February 03 From: Hillsboro, OR Member No.: 364 |
Have you seen this thread about all the different types of 914 Bodywork.
http://www.914world.com/bbs2/index.php?sho...=172075&hl= -Britain |
Alphaogre |
Sep 17 2012, 04:44 PM
Thanks for the input.
As of right now I am not going to run the fenders, I don't have the wheels to fill them yet, and im looking to push that cost off later. I got a set of Fuchs when I bought the car so I would like to stick with those for now. Since the rubber on the bumpers is bad and the rubber is expensive I was looking to jsut replace the bumpers with the FB ones so I didnt have to deal with the rubber. My hood needs some work, so then I though maybe ill just run a FB one of those as well, then I though well if I get rid of that one then I might as well get loose the back one....and so on... (IMG:style_emoticons/default/biggrin.gif) So that is the thought process. Im not looking to build this as a show car, so for me a little lacking on fit and finnish to add performance is fine by me. From looking around I saw the bumper wight loss would be about 40lbs each, and the hoods at about 30lbs or so. Not sure how accurate that is but I will be looking to add a cage, so any weight to augment the weight I am going to ad would be nice. |
carr914 |
Sep 17 2012, 04:53 PM
Racer from Birth Group: Members Posts: 118,332 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
The Getty Design stuff is perfect. I have CF, but assume the FG is the same quality. Fit and finish perfect. (IMG:style_emoticons/default/agree.gif) |
Lo-Fi Version | Time is now: 3rd May 2024 - 01:23 AM |
