odd oil leak, from the dipstick! |
zeezee |
Sep 13 2012, 06:57 PM
Member Group: Members Posts: 115 Joined: 16-October 08 From: san ramon, ca Member No.: 9,651 Region Association: Northern California |
I started seeing oil collect on the top left of the engine. After A LOT of investigation, tests and gasket replacements I found the dipstick not sealing well.
The dipstick had TWO rubber washers. One appears built into the stick, the other may be an add on from a PO?? After removing the extra rubber washer the leak appears to have stopped. Why did it take 4+ years for this to happen? Recent work included replacing lost cooling tins and sealing the engine compartment from hot air leaks. Maybe that work lowered the air pressure in the engine compartment enough to cause the chaos. Thanks to 914rubber for the extra thick oil filler gasket. And if you ever need a rubber grommet that seals around wires and cables, search ebay for "rubber grommet blank" or "rubber grommet closed" - oddly they are sold only in UK. |
Lo-Fi Version | Time is now: 20th May 2024 - 12:39 AM |
