Allan |
Teenerless Weenie ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California ![]() |
Does the alpha numerical designation at the end of a part number indicate something important or is it more like a batch or lot manufacturing number? For example:
021.109.111B VW 3H vs. 021.109.111B VW 15H Thanks |
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
On parts where color is one of the variables, the suffix indicates what color it is. The Cap'n
Allan |
This is an internal engine part. (IMG:style_emoticons/default/cool.gif)
Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,542 Joined: 1-February 03 From: Corona, CA Member No.: 219 Region Association: Southern California ![]() |
i think even is right and odd is left (IMG:style_emoticons/default/wacko.gif)
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
021 = type,model or version
1 = main group 09 = sub group 111 = part number B = modification code Any code after that can be colour, but often it has no meaning as far as a vw/porsche #'s go. BTW....Main Group numbers 1. Engine 2. Fuel tank, exhaust system, heating system (air conditioning) 3. Transmision 4. Front axel, steering 5. Rear axel 6. Road wheels, brakes 7. Hand lever system, pedal cluster (frame) 8. Body 9. Electricial equipment |
Mark Henry |
QUOTE(acox914 @ Oct 27 2004, 07:42 PM) i think even is right and odd is left :wacko: Yep...on the part number...but not if there is no L/R, usually it will end with an odd if this is the case. |
Allan |
Thanks for the info. (IMG:style_emoticons/default/biggrin.gif)
davep |
914 Historian ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,308 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada ![]() ![]() |
Each character means something. This looks like a cam sprocket, and they come in several varieties for the same part depending on the tolerance. Every variance in the part number means a slightly different part. You have to be exact when choosing the correct one. It has nothing to do with lot numbers that would indicate interchangeability.
Lo-Fi Version | Time is now: 31st August 2025 - 12:37 PM |
