1.8 ljet double Relay |
914itis |
Sep 24 2012, 11:02 AM
Is this an Ljet double relay?
ejm |
Sep 24 2012, 11:11 AM
I can see the light at the end of the tunnel Group: Members Posts: 2,691 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
yes
Cap'n Krusty |
Sep 24 2012, 11:33 AM
Keep in mind there are more than one version, and they DO NOT interchange.
The Cap'n |
914itis |
Sep 24 2012, 11:36 AM
infraredcalvin |
Sep 24 2012, 09:31 PM
Distracted Member Group: Members Posts: 1,517 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California |
Keep in mind there are more than one version, and they DO NOT interchange. The Cap'n Thanks , it is a 75 1.8 Where did that come from in the car. I just pulled the whole harness out of my 75 1.8, that does not look familiar... |
914itis |
Sep 24 2012, 09:36 PM
They are located In the engine bay , by the battery .
timothy_nd28 |
Sep 24 2012, 09:46 PM
Keep in mind there are more than one version, and they DO NOT interchange. The Cap'n Thanks , it is a 75 1.8 Where did that come from in the car. I just pulled the whole harness out of my 75 1.8, that does not look familiar... Why did you pull that? Did you switch to carbs? Are you interested in selling it? |
infraredcalvin |
Sep 24 2012, 09:49 PM
914itis |
Sep 24 2012, 09:51 PM
Long story . .... The car had a broken suspension ear, I stripped it 9 months ago and obtained a new shell . I gave it all to my brother and I am helping him putting it back together on the new shell . My knowledge is limited on ljets as my other two are arbs and djet . Tryng to sort things out.
914itis |
Sep 24 2012, 09:53 PM
They are located In the engine bay , by the battery . Hmmm, definitely not found in my car, must be one of the "other versions" as mentioned by the Cap. Btw, mine is a CA car, not sure if that makes a difference in this part. Afaik all ljets have them. I know there is an aluminum looking version. It sits next to the resistor pack. |
infraredcalvin |
Keep in mind there are more than one version, and they DO NOT interchange. The Cap'n Thanks , it is a 75 1.8 Where did that come from in the car. I just pulled the whole harness out of my 75 1.8, that does not look familiar... Why did you pull that? Did you switch to carbs? Are you interested in selling it? Whole car is stripped for a vintage 6 racecar build. Not ready to sell off engine or harness yet... |
914itis |
Sep 24 2012, 09:55 PM
infraredcalvin |
Sep 24 2012, 10:02 PM
Ahh thanks for the description, must be this:
(IMG:http://i1033.photobucket.com/albums/a411/infraredcalvin/race/ee46c9f68c1ad09a002952fa769ffe1e.jpg) |
914itis |
Sep 24 2012, 10:06 PM
You got it!. What year was that?
infraredcalvin |
Sep 24 2012, 10:14 PM
914itis |
Sep 24 2012, 10:20 PM
As the cap'n mentioned there are different ones. I am wondering what is the difference, color, part number or what?
jim_hoyland |
Sep 25 2012, 07:01 AM
Get that VIN ? Group: Members Posts: 9,301 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
The original metal and newer plastic dual relay for the 914 work the same-from my experience. The main difference is in the bases. I prefer the square white base fittings. Also, there is a thread on how to test a dual relay; all that is needed are a 9 v battery and two leads
914itis |
Sep 25 2012, 07:16 AM
Thnks Jim
Cap'n Krusty |
Sep 25 2012, 08:00 AM
The original metal and newer plastic dual relay for the 914 work the same-from my experience. The main difference is in the bases. I prefer the square white base fittings. Also, there is a thread on how to test a dual relay; all that is needed are a 9 v battery and two leads There are different pin assignments as well as different cases and plug configurations. Different part numbers, too. The Cap'n |
type47 |
Sep 25 2012, 08:40 AM
Lo-Fi Version | Time is now: 17th May 2024 - 08:23 PM |
