> Using turn signal turns on my highbeams.
tornik550
post Sep 28 2012, 08:32 PM
Ever since I have owned my car, if I have my headlights on and I use the right turn signal, it turns on or off my high beams. It's very annoying when I am at a stop light and I turn my right signal on and flash my high beams into oncoming traffic. I took the turn signal switch out to look at it and clean it. Everything appears normal. Any ideas?
Mike Bellis
post Sep 28 2012, 08:47 PM
Resident Electrician
The highbeams work by sending a momentary ground to the relay. Something is loose or touching something it shouldn't. Study the brown/white wire and it's connection right at the end of the stalk.
Nine_14
post Sep 29 2012, 07:07 AM
Region Association: Germany
Have you checked all Ground connections ?
tornik550
post Sep 29 2012, 12:56 PM
QUOTE(kg6dxn @ Sep 28 2012, 10:47 PM) *
Every thing in the general area of the switch looks ok. Could this just simply be that I have a bad switch?
- Lo-Fi Version Time is now: 16th April 2026 - 02:15 PM
